Axxess XSVI 2004 wiring interface Help/Question
I am in the process to update my head unit on my 2001 C5, so I got the Axxess XSVI 2004 wiring interface. Not much about the description of the different components. I was wondering how to connect certain plugs assuming they need to be connected somewhere. There are 2 black boxes and 2 wiring harnesses. I am trying to understand certain plugs where they go.
- What do I do with the small black box, the 2 wiring harnesses that came with the kit none of them plug into it and I couldn't find anything in the car to plug into it either
- So the first wiring harness with the white plugs on either end, one end goes into the converter with the dials and the other end goes into the factory harness - CHECK
- The second wiring harness has 3 black plugs and stripped wires.
- The stripped wires I will have to wire with the new Kenwood wiring harness by matching colors - CHECK
- The big black plug gets connected to the factory harness - CHECK
- What about the 2 small black plugs where do they go, I could not find anywhere to plug them.
Below are pictures of the kit and what I am talking about.
Any help on this is greatly appreciated
