Compact Amps for the rear ledge
Anyone run compact amps for components and a sub? I have an Alpine HU, Focal 6.5 performance components and a Vettenuts 10 inch box. Need an amp to run the components and bridge to sub. Figure I'll do head unit for the rears. So I need an amp and a sub.
Was looking at the Arc Audio KS125.4 and the Fosgate T400x4ad. The Arc is a bit cheaper and has a bit more power but doesn't have the auto clipping stuff etc.
Also would need an efficient 10 inch 4 ohm sub with only 200 to 250 watts. Anyone else running a system like this with good results?? I'm not looking to win sound offs just something that is pleasant to listen to and has new android auto features in my 2006 z06.
THanks!
THanks!
I use the JL 600/3 in my vette. It fits into the factory Bose amp location and works well. I am using the JL 8” sub boxes for c6 convertible. JL 650 components in the doors. The system sounds nice and is unobtrusive.
i use the Fosgate 4 channel Tx400/4 in my jeep. It too works well.
I would do a 5 channel amp that way you can run the front, rear, and sub all off the same channel. The new micro amps are small and will do the trick. I did the JL Audio RD 900.5 amp but that may be a bit big for what you want. Plenty of options that are small in size but pack a punch. The real question is how much do you want to spend.
KT
KT
