Sponsored by: Innova
Bose speaker replacement question
Old Dec 16, 2019 | 05:29 AM
ALLEN007's Avatar
ALLEN007
Default Bose speaker replacement question
I have replaced all my speakers but the front Bose (the 8" ones). Can they be replaced just plug and play or is there something else needed?
Old Dec 16, 2019 | 06:13 PM
GCG's Avatar
GCG
Those are subwoofers with dedicated amps mounted right besides them.
It is my understanding that their impedance is just 1 or 2 ohms. That is not common, and if you replace them with 4 ohms units, right there you will be effectively limiting the power output of the subwoofer amps to just 1/4 to 1/2 of their current output with the OEM subwoofers.
On the other hand, there is the issue of physical limitations. These are reverse cone subwoofers mounted in a very tight assembly. Finding an 8-inch aftermarket subwoofer with an impedance of 1 or 2 ohms that also conforms to the physical limitations of the OEM mounting is going to be a challenge
