Sponsored by: Innova
Help Installing Rear coupe speakers
Old Nov 22, 2002 | 04:31 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Help Installing Rear coupe speakers
Got my new rear speakers from mid america.....complete with enclosures and all together....ready to replace originals....one foer one.....
My question is.....How hard is it to replace the whole assy.???
Do I have to tear up carpet.....
What else must I disassemble?????
Can anyone out there give me some hints????
thanks
tony
:smash: :smash: :smash:
[Modified by oldace84, 4:33 PM 11/22/2002]
Old Nov 22, 2002 | 05:13 PM
Kale's Avatar
Kale
Default Re: Help Installing Rear coupe speakers (oldace84)
It's very easy
You "pull the carpet" away from the speaker. Seriously, nothing holds it in there.
Then there's 4 bolts holding the bose enclosure down, undo that, drop new spekaer in, and you'r ein like flint
mid america speakers tho :nonod:
[Modified by Nevermind, 2:17 PM 11/22/2002]
Old Nov 22, 2002 | 08:20 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Help Installing Rear coupe speakers (Nevermind)
Installation procedure :yesnod:
Mid America speakers :nono:
If you had decided to stay with the bose, you could have gotten them much cheaper from Dr. Don or RadioJoe.
You were also half way to a real system. When the other two blow up in a year or two because they are 20 year old pieces of paper, you will complete the cost of what a new system would have cost. :nopity
Old Nov 22, 2002 | 08:30 PM
Kale's Avatar
Kale
Default Re: Help Installing Rear coupe speakers (92TripleBlack)
oh.. i thouight you bought their AFTERMARKET speakers
the bose units come right out after you "pull the carpet" out of the way.
they are held by a little clip, undo the clip, put hte new one in
very very easy
Old Nov 23, 2002 | 04:02 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Since you're just replacing it with another Blose pod then it will take you all of 5 minutes to install it.
You simply take off the speaker grill (held down by four screws) then pull the carpet back. Then remove the four screws that hold the Blose pod down and take it out. Unplug it at the harness; plug it into the new pod and reverse procedure to install the new pod, literally a 5-minute job.
The front door speaker pods on the other hand are quite a bit more entailed. I read in another post that you replaced your door pods already, this will be a cakewalk for you. :yesnod:
To Help Installing Rear coupe speakers
