Sponsored by: Innova
C5 Sub box dimensions?
Old Nov 29, 2002 | 07:26 PM
VFRLuke's Avatar
VFRLuke
Default C5 Sub box dimensions?
I think I'm going to go ahead and try out my hand at building my own box for a 12" IDMAX. I know a lot of you guys have built your own boxes and I was curious if any of you guys could post the dimensions of the box, or anything that might help.
Thanks in advance
Luke
Old Nov 30, 2002 | 01:17 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: C5 Sub box dimensions? (VFRLuke)
sending you drawings and part piece dimensions for a 1.2 cu ft enclosure, you'll need a fiberglass bottom, to fit the bottom of the well. :smash:
Old Nov 30, 2002 | 02:19 PM
VFRLuke's Avatar
VFRLuke
Thanks joe,
I got your drawing's and I'm trying to keep from making a fiberglass enclosure as of now, but I will keep it in mind. I've never done any fiberglass work before.
I do appreciate the drawings though.
Old Nov 30, 2002 | 10:19 PM
M396 #00-011's Avatar
M396 #00-011
http://<a href="http://forums.corvet...?id=247462</a>
Here's MrKln's setup for the very same sub. :cheers:
Old Dec 1, 2002 | 11:09 AM
mrkln's Avatar
mrkln
Default Re: C5 Sub box dimensions? (M396 #00-011)
http://forums.corvetteforum.com/zerothread?id=247462
Minor correction. Those plans were for a 12" solobaric that I had left over from a previous install in another car of mine but I wound up picking up an IDMAX so I rebuilt a different box using 3/4" birch for the sides/top and glassed in the bottom. I used the dimensions from the side panels except I extended the side panels all of the way down to the bottom of the well. I came up with right at 1.2 ft^3 and it sounds very good. :cheers:
Old Dec 1, 2002 | 01:20 PM
mrkln's Avatar
mrkln
Default Re: C5 Sub box dimensions? (mrkln)
Here is a link to the write-up I just did for my IDMAX. I hope it helps...
http://forums.corvetteforum.com/zerothread?id=443985
To C5 Sub box dimensions?
