Sponsored by: Innova
Stereo intermittent no sound
Old Dec 9, 2020 | 11:55 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Stereo intermittent no sound
Hi,
I have a 08 C6 with a aftermarket stereo. It has been working fine until recently there is intermittent no sound.
I start the car and no sound, as i drive around sometimes the sound comes on and stays on but if I turn the car off the next time I run it there is no sound.
So I bought a new HU thinking that would fix it but it had the same issue. So I bought a used factory amp off ebay and same issue. It has a PAC TR-12 and a RP3-GM11 interface, could it be that?
I checked the connections and they look good.
Thanks for any help.
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Dec 11, 2020 | 01:36 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Amplifier wiring issue most likely. Could be a break in the power wire (or "remote" wire) within the harness itself. I feel for you man, that sucks. But in my experience, anything "intermittent" is typically a wiring issue.
