Sponsored by: Innova
Need help with picking head unit
Old Feb 1, 2021 | 11:04 PM
VinceC5's Avatar
VinceC5
My suggestions were more of a simple, very budget friendly solution. And I did mention it would not be the best quality.
If you buy everything from Crutchfield, they usually offer a package discount and charge a small fee to pre-wire the head unit to the PAC adapter making it a simple plug and play solution.
Old Mar 3, 2021 | 12:07 PM
slowtealz28's Avatar
slowtealz28
Just wanted to update. This car will play music through the stock AUX outlet in the center console by opening youtube which is what I usually use to listen to music. Money saved and problem solved.
Old Mar 3, 2021 | 03:47 PM
FAUEE's Avatar
FAUEE
I use a Bluetooth receiver plugged into the aux port and a 12v outlet in my car. Works great, was maybe 30 bucks in total?
Old Mar 3, 2021 | 10:39 PM
VinceC5's Avatar
VinceC5
Originally Posted by VinceC5
Does your GS have AUX input in the center console? I used this in my 13 GS before I replaced the head unit. It worked great. Automatically connected when the car turned on. I could stop/play, FF/RW whatever was playing on the phone. It also had a MIC, but I only connected it for audio.
Kinivo BTC450
I put it right below the shifter and cables ran right into the center console.
hmmmmm.......
