Sponsored by: Innova
How many Hz is an Octave?
Old Dec 17, 2002 | 08:15 PM
korvetkeith's Avatar
korvetkeith
Default How many Hz is an Octave?
How many Hz is an Octave? And ported eclosures roll of at 12db per octave right?
Old Dec 17, 2002 | 11:13 PM
GTLocke13's Avatar
GTLocke13
Default Re: How many Hz is an Octave? (korvetkeith)
The human ear interprets sound on a logarithmic scale. An octave is a doubling of frequency. For instance, 60 Hz is a b flat. The next b flat up is 120 Hz, then 240 Hz, then 480 Hz, and so on. To find the difference between certain notes, use:
F = F0*2^(diff/12)
That's kind of cryptic, so I'll explain it. F0 is the original frequency. diff is the number of half-steps (on the western 12-note chromatic scale) that you want to move. So, if you want to know what the C below A440 is, you get:
F = 440*2^(-9/12)
F = 261.63 Hz
You can replace (diff/12) with the number of octaves you want to move. If you want to know what a half-octave below 35 Hz is, just use -1/2 there.
You can figure out how many octaves are between two different frequencies by using:
Octaves = log2(F/F0)
log2 means log base 2. I don't think I can do subscripts here. So if you have a low-pass first order filter that cuts off at 80 Hz and you want to find how much it attenuates 100 Hz signals, just do:
Octaves = log2(100/80)
then
dB = Octaves * -6dB/octave
I can't do that math on the crappy calculator program that windows has, but you get my point.
And yes, ported enclosures roll off at 12dB per octave.
[Modified by GTLocke13, 11:14 PM 12/17/2002]
Old Dec 17, 2002 | 11:58 PM
korvetkeith
Default Re: How many Hz is an Octave? (GTLocke13)
http://forums.corvetteforum.com/zerothread?id=454615
[Modified by korvetkeith, 11:00 PM 12/17/2002]
Old Dec 18, 2002 | 06:50 AM
IMQUIK's Avatar
IMQUIK
He knows his shiat! :D
Old Dec 22, 2002 | 10:43 PM
jfb's Avatar
jfb
An octave is a range of frequencies with the highest frequency twice the lowest frequency.
Old Dec 23, 2002 | 10:07 AM
FlyNavy's Avatar
FlyNavy
There is no specific number of Hz in an octave. And octave represents a doubling of frequency. Hence 20 Hz in an octave above 10 Hz which is a 10 Hz change. But, 2000 Hz is an octave above 1000 Hz which is a 1000 Hz change.
Old Dec 23, 2002 | 03:31 PM
bogus's Avatar
bogus
GT,
Thats most interesting... its all beginning to make sence now...
Thanks! :cheers:
To How many Hz is an Octave?
