Multiple questions for C5 install
How much dynomat does it take to properly deaden a C5? I'm going to get an IDMAX from sounddomain and they give you a trunk kit which is like 8 ft^2 of dynomat extreme and 12 ft^2 of normal dynomat.
I'm going to be getting an alpine cda-7998 and I was wondering about the way that the c5's dash is somewhat recessed. If I get the metra kit with the little compartment under the stereo (99-4000) then would the oversized face of the 7998 hit the part of the dash above it or should I get the kit that keeps the stereo more centered?
As far as my shopping needs, Who's the cheapest AUTHORIZED Focal and Alpine dealers on the web?
Thanks in advance guys :D
Luke
I would say, about 70 ft^2 would do the whole car good. Look for Rammat or BrownBread, cheep and as good as dynamat.
:cheers:
[Modified by M396 #00-011, 11:40 PM 12/18/2002]
The meta kit with the pocket, mounts the head unit at the top of the dash opening and it "sticks out" about 3/8" of an inch from the surrounding trim.
Because of this "sticking out" I decided to go back to the "normal" GM install kit. The metra kit might work better for you with the active face plate on the 7998. I'll sell you mine if you are interested.
:cheers:
:cheers:
[Modified by leolufse, 12:06 PM 12/19/2002]
