Sponsored by: Innova
audio question
Old Oct 30, 2021 | 04:17 AM
abhi.s's Avatar
abhi.s
1st Gear
Default audio question
Hey guys so i just got a c5 and it has a crappy boss touchscreen along with everything else stock i believe. I wanted better audio quality so i just ordered a JVC headunit along with the interface to make it compatible with the bose system. And I thinking about upgrading just the speakers in the doors and back the 3.5 and 6.5. I saw on other threads that with the bose audio system its finiky to run aftermarket things but it only runs the 8in woofers in the door. Am I able to just connect the aftermarket 3.5 and 6.5 in speakers to the stock harness and run it along with the bose amp? or would I need to ditch the bose system completely to run anything else? So all in all i would have the JVC double din with the interface connector, and aftermarket 3.5 and 6.5s everything else stock.
Old Nov 1, 2021 | 05:32 PM
VinceC5's Avatar
VinceC5
That should work. Depending on your ears, don't know how much of an improvement it will be.
Old Nov 13, 2021 | 05:33 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Depends on your budget and what you're wanting from it OP. Just putting in a HU and speakers will do very little in the way of improving sound quality. Quality will not improve without an amplifier. Just my .02.
To audio question
