Sponsored by: Innova
3.5 Aux port
Old Oct 31, 2021 | 10:07 AM
Whoop's Avatar
Whoop
Default 3.5 Aux port
I was playing around with the 3.5 audio jack in the center console on my 2011. I plugged in a android phone and the aux button lit up on the head unit but no sound while trying to stream from the phone. Can someone enlighten me as to what you can and can't do with the aux port? I did read where it looks like it might only work with MP3 and Ipods? True?
Old Oct 31, 2021 | 11:36 PM
MrMcE's Avatar
MrMcE
If it's a 3.5 aux port, then the source of the signal makes no difference. That information is not carried over the audio signal whether it's an ipod or phone or whatever.
Make sure your phone is playing audio out of its port. You might have inadvertently connected to a bluetooth audio device which is taking the audio instead. Try plug in headphones to confirm your phone is putting out audio. Don't forget to check volume, some phones turn volume really low on plugin.
Old Nov 1, 2021 | 08:42 AM
Whoop's Avatar
Whoop
Ok, that is what I thought. I will check a few things and your suggestions.
To 3.5 Aux port
