Sponsored by: Innova
Can I cut/splice camera wire ?
Old Jan 20, 2022 | 05:11 PM
TxTom's Avatar
TxTom
Default Can I cut/splice camera wire ?
installed a front camera in c6 using a Natika camera from amazon, worked fine UNTIL
it got hung up on the wiper motor, I routed the wire too close to it. stopped the wipers from working. easy fix snapped the wiper transmission back together.
I would rather not pull out the head unit to plug in a new camera wire, so I am wondering if its possible to splice the broken camera wire back together ? guess I can try it easy enough and see
Old Jan 20, 2022 | 10:25 PM
madsonp's Avatar
madsonp
Well they are shielded wires, but I've done it before. Usually the wires are pretty small and difficult to work with, and you'd want to keep your splices as short as you can so as not to compromise the shielding to much, otherwise other electronics of the car could cause interference with the picture. I'd also suggest covering your repair with some marine grade heat shrink tubing to make sure it's sealed well against any moisture that could affect it. So yes, I say go for it.
Old Jan 20, 2022 | 10:31 PM
TxTom's Avatar
TxTom
thanks I will give it a try
Old Jan 20, 2022 | 10:36 PM
madsonp's Avatar
madsonp
Let us know how things turn out.
To Can I cut/splice camera wire ?
