Sponsored by: Innova
Radio circuit short.
Old Dec 30, 2002 | 03:25 PM
Mikedril's Avatar
Mikedril
Default Radio circuit short.
Hi all. I am new to this forum and have learned a lot from you all over the last month or so.
I bought my Son a 1986 Vert. for Christmas. The only problem that I have found with the car (so far) is a bad door lock actuator switch on the driver side and a power drain in the radio circuit. I have purchased a new switch for the door locks and plan to install it this week (thanks to the help of Sam Lam's instructions). I would also like to track down the radio circuit problem. The problem is that the battery will go dead over night IF I leave the radio circuit fuse in. If the fuse is removed, the battery holds a charge with no problem. The previous owner was told that there was probably a bad amp.
Any advise will be greatly appreciated.
Mike :flag
Old Dec 30, 2002 | 11:24 PM
GTLocke13's Avatar
GTLocke13
Default Re: Radio circuit short. (Mikedril)
Try unplugging the connectors from the back of the radio. If the battery still goes dead, the short is in the power wire to the radio. If the battery holds a charge, its time to get a new radio.
Old Dec 30, 2002 | 11:43 PM
Mikedril's Avatar
Mikedril
GTLocke13,
Thank you for the reply.
I understand that there is a delay that allows the radio (and interior lights) to run, for a short period of time, after the ignition/accessory switch is turned off. Is power still supplied to the radio after the delay switch turns off? :confused:
Old Dec 31, 2002 | 12:00 AM
GTLocke13's Avatar
GTLocke13
Power is always supplied to the radio, to keep the clock running and hold the station memories. There may be a short in the power supply that's causing it to draw more current than it should. Or the short may be in the power wire going to the radio. The test in my last post should point out where the short is.
Old Dec 31, 2002 | 12:03 AM
Mikedril's Avatar
Mikedril
Default Re: Radio circuit short. (GTLocke13)
Thank you sir!! That makes good sense. I will give it a try.
Old Jan 2, 2003 | 06:01 PM
Mikedril's Avatar
Mikedril
Ok ... one more question. What is the easiest way to get to the stereo power wire and disconnect it? I haven't torn into anything 'cept the door pannel and air cleaner so far. Thanks in advance for any help.
Old Jan 4, 2003 | 12:56 AM
jfb's Avatar
jfb
What do you mean by, "stereo power wire" ? The radio is the source of program material for the external speaker amplifiers in the Delco-Bose optional radio. Also, the radio operates a power relay that supplies 12v to the external audio amplifiers. The power to the radio is within the bundle on one of the connectors that plug into the back of the radio. The 12v line on my 87 is yellow (don't know if it is the same for 86).
Old Jan 4, 2003 | 08:00 PM
Mikedril's Avatar
Mikedril
Default Re: Radio circuit short. (jfb)
Thanks JFB, but whats the easiest way to get to the wires? do you come in from underneath or take off the dash pannels? I have not torn into the dash yet. I have a service manual on order but it won't be here for another 4 days.
Thanks again.
Old Jan 5, 2003 | 12:52 AM
jfb's Avatar
jfb
Remove the dash panel over the radio, then remove the 4 screws that holds the radio onto the dash. Pull the radio out and unplug the connector with the yellow wire on it and this will remove power to the radio. Why not just remove the radio fuse?.....much easier.
Old Jan 8, 2003 | 12:20 PM
92TripleBlack's Avatar
92TripleBlack
With the car off, open the door and depress the plunger switch in the door frame to make the car think its closed. Wait for the lights to go out. Now test the fuses with a meter to see where the draw is. It could be a bad amp instead of the deck that isn't turning off, vanity mirror, hood or storage light not going off, etc.
To Radio circuit short.
