Sponsored by: Innova
XM antennas
Old Jan 3, 2003 | 02:16 AM
84FromHell's Avatar
84FromHell
Default XM antennas
What type of antenna do you have and where did you mount yours?
Old Jan 3, 2003 | 07:50 AM
Patrick's Avatar
Patrick
Cruise-In I Veteran
Default Re: XM antennas (84FromHell)
Hopefully you can see my Delphi XM SKYFi antenna simply placed on the dash near the passenger side window frame. It works perfectly - no need for anything else. Is this simple enough?
Patrick in DC
[Modified by Patrick, 7:52 AM 1/3/2003]
Old Jan 3, 2003 | 11:51 AM
ICULUKN-C5's Avatar
ICULUKN-C5
I have a Terk.. mounted it in the rear facia...
There is a shelf in the middle of the car, that it can sit on.
Old Jan 3, 2003 | 01:47 PM
unclemeat's Avatar
unclemeat
Mine is mounted right under the top of the right rear quarter panel. I asked for a rear facia mount like I'd seen so many times here but the installer couldn't figure out how to get to the location. Rather than call he found another location that seems to work pretty well. The signal goes through plastic and rubber without a hitch but when I lean over the car while applying Zaino it does drop out.
Old Jan 3, 2003 | 05:43 PM
lawman34203's Avatar
lawman34203
St. Jude Donor '13-'14
On the shelf in the rear facia. I took out one of the tailights to gain access. Cleaned the surface of the shelf real good, and the antenna just stuck on without any problems. :cheers:
Old Jan 5, 2003 | 02:27 PM
JT-C6's Avatar
JT-C6
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Default Re: XM antennas (lawman34203)
I'm in the rear fascia club too. Terk SR-2 sits nice in there.
Old Jan 5, 2003 | 03:08 PM
heartless's Avatar
heartless
Cruise-In III Veteran
Default Re: XM antennas (JT-C5)
Rear Fascia here...
To XM antennas
