I am hoping someone might have experience and an answer for my situation. I have a 1965 that I installed a crate LS3 motor. I purchased an aftermarket fuel tank from CPP with a 60 psi fuel pump installed. Their sending unit is a single wire sending unit, not the 2-wire standard on the 1965. I did order and receive a 90 ohm sending unit. I did wire the system as they recommended. I used the ohm (tan) wire and attached it to the center post on their sending unit. I then grounded the sending unit to the system ground in the rear wiring harness. This wiring setup does afford the resistance in the sending unit to send a signal back to the gauge. The problem I am having is that the gauge reads full when the float is raised, buy only drops to 3/4 full when the float is in the lowest position (empty). I have replaced both the sending unit and fuel gauge twice, and they are both rated at 0-90 ohm
Any suggestions would be appreciated.
I don't think that setup can work with a mid-year fuel gauge because it expects the sender to behave like a 12V sourced, 0-90 ohm potentiometer with the tan wire connected to the wiper. The 1-wire sender is just a 0-90 ohm variable resistor to ground. I believe your sender would work with a C3 fuel gauge.
