Sponsored by: Innova
Adding Sub Amp to 99 vette Factory Bose system
Old Aug 22, 2023 | 01:22 PM
DaytonaRacer's Avatar
DaytonaRacer
Default Adding Sub Amp to 99 vette Factory Bose system
Hello All.. After a long search I finally found the vette I was looking for.. Looking thru countless posts helped me with important decisions and the knowledge here is so helpful.
I have been reading countless posts on how to add a pre amp output without the OEAM-VET1 plug and play module as its no longer available.
If I understand correctly, I can splice into the LF and RF speaker wires coming out of the head unit, and attach a pre amp like a pac SNI-35
I have a couple more questions for anyone who has had to do the same
Thanks so much
Old Aug 22, 2023 | 03:14 PM
VinceC5's Avatar
VinceC5
You have to tap into the sub signal wires at the back of the radio.
https://www.corvetteforum.com/forums...post1572701744
and go with something like the audio control LC2i.
Old Aug 22, 2023 | 03:25 PM
DaytonaRacer
Thanks Vince C5....There are 2 plugs on the back of the factory head unit... Which plug would i use?.. If the tan/blk wire is positive from the L Front speaker, which wire would be the negative?
Old Aug 22, 2023 | 04:00 PM
VinceC5's Avatar
VinceC5
The bare/drain wire is the ground.
Old Aug 22, 2023 | 04:09 PM
DaytonaRacer
Thanks Again, so that tells me which plug/wires to use. Facing the unit, that's the plug on the left side
What are the wires on the other plug for?
Sorry for the 1000 questions
Old Aug 22, 2023 | 04:47 PM
VinceC5's Avatar
VinceC5
Quick, short explanation
https://www.corvetteforum.com/forums...post1592945984
Old Aug 22, 2023 | 05:03 PM
DaytonaRacer
Now Im even more confused.. lol The plugs I have contain 2 rows A1-A12 on top B1-B12 on the bottom A8 is the dark green wire which I was told to use as a remote turn on for sub amp
Old Aug 22, 2023 | 05:08 PM
VinceC5's Avatar
VinceC5
A8 is the right wire for remote turn on lead.
Old Aug 22, 2023 | 05:51 PM
DaytonaRacer
i guess when i take the head unit out again, i will post a picture of the back.. there are 2 wiring harnesses going into it. one on each side.. thats where im not sure on which side to splice into... I just dont want to splice into the wrong one and cause damage
Old Aug 23, 2023 | 08:25 AM
DaytonaRacer
Hi Again,
I had the opportunity to go thru both links you sent me. Each link has a wiring diagram but they are different
Why is that, and which one to use?
Old Aug 23, 2023 | 05:30 PM
VinceC5's Avatar
VinceC5
Not sure of the differences, but use the one that matches your connector. The C5 had many different units... CD, cassette, CD changer, etc...
Old Aug 24, 2023 | 06:29 PM
DaytonaRacer
Discountcarstero.com has a CIM-C5, which is an AOEM-VET1 adapter... Austin was excellent to work with.. It is arriving tomorrow.. easy installation... Plug and play.. only have to connect dark green (Pin 8 wire on 20 pin connector) to module for remote AMP turn on...
Thank you also for all your help Vince..
Old Aug 24, 2023 | 06:53 PM
VinceC5's Avatar
VinceC5
that's awesome. Post a link to that adapter as I'm sure others will find it helpful.
Old Aug 24, 2023 | 08:39 PM
VinceC5's Avatar
VinceC5
Found it.
Install aftermarket amplifier to C5 Corvette and retain rest of the system.
https://www.discountcarstereo.com/aim-c5.html
Old Aug 24, 2023 | 09:01 PM
DaytonaRacer
https://www.discountcarstereo.com/ai...ab-description
CIM-C5 Adapter
Old Aug 27, 2023 | 04:57 PM
DaytonaRacer
Hey Vince.. Forum will not allow me to send you a PM.. says you need to clear space..
Old Aug 27, 2023 | 05:04 PM
VinceC5's Avatar
VinceC5
@DaytonaRacer cleared up some space
Old Aug 28, 2023 | 07:32 PM
DaytonaRacer
Vince, Thanks for all your help with this project.. It turned out great and sounds awesome!
To Adding Sub Amp to 99 vette Factory Bose system
