Sponsored by: Innova
Radio sound issue
Old Oct 7, 2023 | 12:59 PM
GaryZ06's Avatar
GaryZ06
Default Radio sound issue
Hey guys I have an issue with my stock (non Bose) radio in my C6.The problem is that there is no sound but the radio is on....and also there are no other sounds in the car such as any chimes like the seatbelt or when I push any of the dashboard buttons.......I took out the amp and put in another one and the same which looks like it's not an amp issue....also checked amp and radio fuse....BUT once in a while(very rare) it will work......any ideas ? Thanks
Old Feb 18, 2024 | 04:21 PM
VloneVett's Avatar
VloneVett
8th Gear
This sounds like the same problem that I have going on in my c7. Did you figure out what was wrong with yours?
Old Mar 9, 2024 | 12:11 PM
GaryZ06's Avatar
GaryZ06
No not yet
Old Mar 11, 2024 | 10:45 AM
madsonp's Avatar
madsonp
I suggest pulling it out and pull the connectors, and spray with some contact cleaner, then plug them back in and making sure they’re good and secure, could just be a little corrosion on the connections.
Old Mar 11, 2024 | 03:46 PM
NBVette_Canada's Avatar
NBVette_Canada
I'd also suggest "wiggling" the fuse a bit to see if it might be loose contacts.
To Radio sound issue
