Sponsored by: Innova
Audiovox radio wiring
Old Nov 29, 2023 | 03:29 PM
Richard01's Avatar
Richard01
Default Audiovox radio wiring
Trying to install this audio box in my C3,speaker wires are clearly marked however there are 4 other wires colored pink black yellow and gray. Does anyone know how to wire them?
Last edited by Richard01; Nov 29, 2023 at 03:34 PM. Reason: Forgot to include pictures
Old Nov 29, 2023 | 05:04 PM
VinceC5's Avatar
VinceC5
Check out the pictures in this listing... it's a radio made for Gm, so the colors should match with the car side.
https://www.ebay.com/itm/314959602940https://www.ebay.com/itm/314959602940
here are the colors for a 1980
Old Nov 29, 2023 | 05:09 PM
Richard01's Avatar
Richard01
Default Audiovox wiring
Thanks for the thought I'm going to check it out however some of the wiring in this car was butchered at one time I will try to follow it back to see if I can locate the same color wires
Old Dec 5, 2023 | 10:03 AM
BandDirector's Avatar
BandDirector
I also found this pic of an Audiovox radio on eBay, and it’s clear those 4 wires were in a harness together separate from the speaker harness. Here’s my call based on the above links and my car audio experience:
Pink = Power Antenna
Black = Ground
Yellow = Power
Gray = Illumination/Dimmer
To Audiovox radio wiring
