Sponsored by: Innova
what else
Old Jan 24, 2003 | 06:25 PM
pdd000's Avatar
pdd000
Default what else
ok guys i just bought a kicker kx800 2 channel, a kicker kx600 4 channel, a ausiobahn sub box with 2 tens and a alpine 7998. im gonna try the install myself. what else will i need to finish it up pat
Old Jan 24, 2003 | 07:09 PM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
Default Re: what else (pdd000)
Is the box made especially for a C5, or how does it fit?
Old Jan 24, 2003 | 07:33 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: what else (Drop_Top_Dave)
have you upgraded your wiring yet? If not you'll need to do that as well :cheers:
Old Jan 24, 2003 | 07:39 PM
baldie's Avatar
baldie
St. Jude Contributor
Just out of curiousity, what do you mean by upgrading the wires? I am running an install at this very moment and I have 4 gauge coming off the batt term all the way back to the amps. Is this the upgrade you speak of?
Old Jan 24, 2003 | 07:51 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: what else (baldie)
ground to batt, batt to alt, alt to ground
sometimes the alt is grounded to the engine so you find the engine ground wire and replace that, they should all be 4ga or bigger
:thumbs:
Old Jan 25, 2003 | 08:31 AM
pdd000's Avatar
pdd000
its just a regular box but with the tens it will fit in the trunk area perfect
To what else
