Sponsored by: Innova
1980 Corvette audio system upgrade?
Old Feb 27, 2024 | 03:27 PM
Tech141's Avatar
Tech141
Default 1980 Corvette audio system upgrade?
I have a 1980, and am looking at upgrading my upgraded sound system.
Currently I have a New Head unit in the console, a 150W, 4-channel amp in the passenger side, behind the seat storage box, and a custom-built speaker box holding a pair of 6x9 speaks. To put it bluntly - it leaves a LOT to be desired.
Last weekend, at my daughter's softball tournament, one of the parent's brought in a JBL Xtreme 3 wireless speaker to do the walkup music for the players. DAMN - That thing sounded great! It gave me an idea.....
Looking at removing the amp and speaker box. Mounting two (linked) JBL Xtreme speakers under the cargo cover. Installing a USB charging station/ports in the passenger storage box, running charging cables to the speakers, wired to be 'On' only while the car is on..
when done, I should be able to play music on the speakers using my phone app, and should still be able to run radio channels through the head unit (bluetooth connection).
Sounds pretty easy, and those JBLs should be more than enough for the Vette. Whatcha Think?
Old Feb 27, 2024 | 08:36 PM
VinceC5's Avatar
VinceC5
Head unit may have Bluetooth, but probably just a receiver and not a transmitter.
The rest sounds doable if that's what floats your boat.
I would spend those $600 or so dollars on something else. But that's just me.
Old Feb 27, 2024 | 09:00 PM
Tech141's Avatar
Tech141
I found a really good deal (sub $200) on a speaker (JBL Xtreme 3), and it is on the way. The one speaker they had out on the softball field, and the display/test speakers in various stores gives me hope that my efforts aren't in vain.
We shall se. If nothing else it will be interesting. Ya know?
Old Feb 28, 2024 | 10:39 AM
madsonp's Avatar
madsonp
You’ll have to let us know how it turns out when you get it done. And don’t forget the pictures, for as we know,
Old Feb 28, 2024 | 12:50 PM
Tech141's Avatar
Tech141
Roger that, and will do. Might be a bit as I am rebuilding my 350 right now but I will definitely follow up.
Old Mar 6, 2024 | 09:36 AM
Tech141's Avatar
Tech141
Have a second JBL Xtreme 3 on the way. Did a test with the first one and it sounds really good in the car. Looking forward to getting the second one.
Now I just have to figure out how to mount them under the cargo cover. There are two strap hangers on top..... and that's about it for factory-stuff mounting.
Any ideas?
Old Mar 6, 2024 | 08:47 PM
VinceC5's Avatar
VinceC5
Any ideas?
something like this would work well.
you can get them made out of plastic also to keep the cost down.
Old May 2, 2024 | 12:53 PM
Tech141's Avatar
Tech141
Interesting. Thanks for posting that.
Still working on other things right now, but will update when I FINALLY get to working on the audio system.
Old May 2, 2024 | 04:34 PM
VinceC5's Avatar
VinceC5
Tried a different search and found something better
Mount from etsy
To 1980 Corvette audio system upgrade?
