Sponsored by: Innova
amp wires
Old Jan 30, 2003 | 05:07 PM
pdd000's Avatar
pdd000
Default amp wires
i have a c5. how do i get the wire through the firwall :jester
Old Jan 30, 2003 | 05:08 PM
pdd000's Avatar
pdd000
Default Re: amp wires (pdd000)
o i forgot im installing my radio and amps so i was was wondering how to get the amp wires through the firewall :crazy:
Old Jan 30, 2003 | 05:35 PM
leolufse's Avatar
leolufse
there is a large rubber boot that goes through the firewall in the passenger footwell area. Remove the battery (and replace with an optima) and you will see it. From the inside of the car you will need to remove the cover on the fuse panel, and some of the trim under the glovebox. It is "higher" up on the firewall that it appears.
To amp wires
