Sponsored by: Innova
no audio
Old Oct 1, 2024 | 08:29 AM
RobbinR's Avatar
RobbinR
Cruising
Default no audio
hello
Anyone had issues with sound when an android unit, new speakers, external amp and wiring and subwoofer installed. I did this install and now I have no sound. Any suggestions would be appreciated.
Robbin
Old Oct 1, 2024 | 12:59 PM
madsonp's Avatar
madsonp
What head unit and interface do you have ?
Old Oct 1, 2024 | 01:39 PM
RobbinR's Avatar
RobbinR
Cruising
Maxdin by Knightdrive
This is a complete plug and play. Only interface is the Bose attachment thats included
Old Oct 1, 2024 | 01:59 PM
jcgunn's Avatar
jcgunn
Never heard of them. Call the manufacturer with the problem.
Old Oct 1, 2024 | 04:06 PM
madsonp's Avatar
madsonp
I believe the MaxDIN is plug and play when using just the stock Bose amp since you have an aftermarket amp it may require changes in the wiring to that amp for it to work, like mentioned above, I’d contact the manufacturer of the MaxDIN to find out what you need to do different
Old Oct 1, 2024 | 10:18 PM
Im.Ur.Leader's Avatar
Im.Ur.Leader
Banned Scam/Spammer
@KnightDriveTV should be able to help you out with this
Old Oct 2, 2024 | 06:12 AM
RobbinR's Avatar
RobbinR
Cruising
I appreciate your input. I will definitely reach out to Knightdrive. Thanks
Old Oct 2, 2024 | 06:13 AM
RobbinR's Avatar
RobbinR
Cruising
Old Oct 5, 2024 | 11:47 AM
backlater's Avatar
backlater
Connect the 12V acc/ign wire directly to the Amp Turn-On wire.
Old Oct 7, 2024 | 08:15 AM
RobbinR's Avatar
RobbinR
Cruising
Where would I access the 12V acc/ign wire and what color is it
Robbin
Old Oct 7, 2024 | 12:18 PM
backlater's Avatar
backlater
Robbin
Your radio - headunit will have a RED wire labelled "accessory / ignition." You may also have an interface module (to retain chimes, RAP etc). and it will also have a RED wire labelled "accessory / ignition." Just connect this red wire to your amp turn on wire.
If you need an external "accessory / ignition" wire, on a C6 corvette, you can add a fuse buddy to the Wiper- Washer fuse that is located in the passenger footwell (remove the black cover that hides several fuses.)
Old Oct 7, 2024 | 01:46 PM
RobbinR's Avatar
RobbinR
Cruising
Many thanks
Old Oct 7, 2024 | 08:07 PM
madsonp's Avatar
madsonp
See if this helps.
To no audio
