Sponsored by: Innova
C6Z MT Reverse Lights Dont Work
Old Apr 19, 2025 | 12:03 PM
NortheastZ06's Avatar
NortheastZ06
Default C6Z MT Reverse Lights Dont Work
In the middle of a stereo installation and having some issues with the back-up camera due which turns out to be due to the fact that my reverse lights are not engaging when shifting into reverse. This is a 2008 C6Z with manual trans. The reverse lights do come on when unlocking the car with the FOB. Both fuses are good (under the hood and in the pass side floor pan). Not sure where to go from here. I would like to try to resolve this myself since the entire dash is apart and really need to ensure stereo wiring is good before buttoning everything back up.That being said, I am skilled enough to be dangerous when it comes to electrical how-to. Tell me what to do, but dont expect me to fully understand "why".
Old Apr 19, 2025 | 01:15 PM
madsonp's Avatar
madsonp
I replied to your PM before I saw this post, one thing I’d suggest, is checking the fuses with a multimeter for Ohm’s and not just visually, I’ve had fuses that looked good, but checked bad using a multimeter.
Old Apr 19, 2025 | 03:35 PM
madsonp's Avatar
madsonp
If the fuses test ok, see post #2 in this thread. https://www.corvetteforum.com/forums...t-working.html
Old Apr 22, 2025 | 03:36 PM
NBVette_Canada's Avatar
NBVette_Canada
There is also a sensor/switch in the transmission (at least for a manual transmission) that tells the car you have the transmission in reverse. This switch/sensor does fail which will cause the issue you describe (ask me how I know).
From what I remember, it wasn't an overly expensive fix.
Old Apr 28, 2025 | 03:42 PM
NBVette_Canada
Did you ever get your reverse lights fixed?
Old Apr 28, 2025 | 06:34 PM
madsonp's Avatar
madsonp
Yes he got them working, I was in a PM conversation concerning this, and his install, and this is what he replied to me concerning his backup lights. Still not sure exactly what the issue was, but at least they’re working
Life is funny sometimes. I debated whether or not I wanted to put the car back together before replacing the reverse switch because I would not have the ability to test it. I decided that I was going to rewire the PAC the way I had it originally, leveraging the purple/white wire to engage the camera when putting the car in reverse. I decided to do that because that's the way it is supposed to be done, and it should work. So I removed the wire I ran that would have been connected to the reverse light wiring in the car and re-soldered my purple/white wire back together. I made all my final connections, cleaned up all my wiring with zip ties and tested the head unit functionality. All was working good so I put the dash back together. I decided to take the car for a ride yesterday and low and behold, when I got back from the ride and backed into my driveway, the back-up camera came on! I asked my son to get out of the car and check my reverse lights, and sure enough, they worked also. The only explanation that I can come up with for this, was that I did all the work on Easter Sunday. My mom came over for easter dinner with new Palms from Palm Sunday. Before I took my ride I pinned my palm cross on the sun visor.
Old Apr 30, 2025 | 09:37 AM
NortheastZ06
They have been working.....mostly. There have been a couple occasions where they don't work exactly as they should. One occasion, I went to back-up and the camera did not engage on shift to reverse and then a few minutes later when I backed up, it did. There was also one occasion where the camera was cutting in and out before it stayed steady on. I noticed if I shift into reverse with a purpose, it tends to engage more reliably. I am assuming that the reverse lights are doing the same thing but was alone and did not have the ability to validate the reverse lights. I'm not sure exactly how the system works so, could this be the switch at the transmission starting to fail, or is there a mechanism in the shifter that may be compromised somehow, maybe the relay?
Old Apr 30, 2025 | 10:20 AM
madsonp's Avatar
madsonp
They have been working.....mostly. There have been a couple occasions where they don't work exactly as they should. One occasion, I went to back-up and the camera did not engage on shift to reverse and then a few minutes later when I backed up, it did. There was also one occasion where the camera was cutting in and out before it stayed steady on. I noticed if I shift into reverse with a purpose, it tends to engage more reliably. I'm not sure exactly how the system works so, could this be the switch at the transmission starting to fail, or is there a mechanism in the shifter that may be compromised somehow, maybe the relay?
Personally, I think I’d replace the switch, as it might be going out, and I don’t think it would cost that much
Old Apr 30, 2025 | 10:21 AM
NBVette_Canada
This sounds exactly like what mine was doing, it would work intermittently, not work initially and then suddenly start working, or simply not work at all.
In my personal opinion, you have a defective backup switch in the transmission (this is how it detects that your manual transmission is in reverse) that is intermittent. This will only get worse. From what I remember, it isn't a huge ordeal to change this switch.
Since I've changed mine several years ago now, I've had zero problems (knock wood).
Old Apr 30, 2025 | 12:23 PM
NortheastZ06
Thanks for the feedback. I'm hoping it will hold out for the season and I can get it done when I have the oil changed and not have to make a separate svc appointment
Old Apr 30, 2025 | 01:37 PM
madsonp's Avatar
madsonp
Deleted
Old Apr 30, 2025 | 01:41 PM
madsonp's Avatar
madsonp
Deleted
To C6Z MT Reverse Lights Dont Work
