howdy.. 02 Z, upgraded to a Kenwood 2020 has performed flawlessly, changed the tweeters 2023,
now the subs are done, took to my local stereo shop and says they are both toast, probably one
went out and i didn t notice too much, car is fairly loud, and i keep the stereo positioned to the back
more than center. What can i replace the subs with ? have done some research and know it is all one unit
and the amps are attached to the subs.. not sure what my options are. Stereo shop says he can change
it up but would be $1400, don t think i need to spend that just to have a little bass.. any thoughts be
appreciated..
TIA
deciding not to go fleaby oem... 25 yr old speakers.. end up having the same problems maybe shortly after
i have looked at many of your threads. there is one in particular, but can t find it 1 hr later.. lol
it was suggestions about the JBL speakers. followed your advice and installed the twiddlers and the rear speakers..
can you point me in that direction again please.. am thinking of putting the JBL woofers or facsimile in.the doors
tisa
LOL yea.. the hole is getting deeper, trying to my way up again...
you had a thread last yr i think.. was about JBL install in C5, i did the JBL twiddlers and the JBL in the back. would like to
keep the JBL for the woofers also.. do you remember which one it was ? or remember the thread, i searched for over
an hour today, couldn t find it
in my personal c5, I ran kicker 8 inch midbass speakers.
I've recommended stereo integrity, morel, kenwood, and some others. Usually speakers that can play well in doors and can handle frequencies from around 60hz to 500 or even 800 hz.
i am still struggling what i need to do, i want to put in the 8" speakers. but looking at Metra, it looks like only 6 3/4 adaptors are available..
is this true, am i missing something, if someone can enlighten me, would be appreciated.
it's true. You can build your own or you can use the metra with an 8 inch ring adapter. Good plastic ones on Amazon. You can use 6 inch speakers if you want. Most are satisfied with that. I'm the oddball that just wants that extra low end midbass from the 8.. or now 10 in my c7.
thanks for all your baby sitting of me Vince.
i think am going with a 6.5 coaxial, am def not an audiophile as everyone can see.
don't give up yet! Totally worth doing an 8 inch. 😃 is not s complicated as it sounds.
or at least go with a component system. It will produce better bass.
hopefully my last question to bother anyone. i appreciate ALL the advice and suggestions.
will a speaker depth of 2.44 fit in the door using the Metra adaptor ?
