Sponsored by: Innova
Head Unit upgrade C5
Old Aug 11, 2025 | 03:35 PM
BobbyC5's Avatar
BobbyC5
Default Head Unit upgrade C5
I'm looking to upgrade my current Pioneer X920BT to something more modern with Apple car play. My question is: If I replace it with a current Pioneer unit, can I reuse the harness and PAC-ROEM, hopefully leading to a simpler install?
Also, any recommendations on mid range units would be appreciated.
Thanks!
Old Aug 11, 2025 | 04:55 PM
madsonp's Avatar
madsonp
Thanks!
Well it may be possible to get a newer Pioneer system that’ll plug into using your old harness, it just depends on if Pioneer didn’t change their wiring configuration or connectors since yours was made. I suggest looking on Crutchfeilds web site for a Pioneer system that has the features you’re looking for, then give their tech support a call and ask if the harness from your old one will work with the new one you’re interested in. Here’s a link to the Pioneer systems they have. https://www.crutchfield.com/g_300/Al...rand%7CPioneer My guess is that they’d be different, so you’d probably have to cut the old head unit harness away from the interface, and wire up the new harness to the interface which isn’t to difficult,
Old Aug 11, 2025 | 11:12 PM
BobbyC5's Avatar
BobbyC5
Great suggestion. Thanks!
Old Aug 11, 2025 | 11:39 PM
madsonp's Avatar
madsonp
Or let me know which one you’re interested in and I can probably compare pictures of the harnesses and tell you if they’re different or not,
To Head Unit upgrade C5
