Sponsored by: Innova
CD Changer + Stock HU C4
Old Feb 19, 2003 | 04:49 PM
TerryMathews's Avatar
TerryMathews
Default CD Changer + Stock HU C4
Anyone have some pics of installs on this combination. Not really interested in changing out the HU, or really modifying the car in any way. As I understand it, the antenna connector is in the equippment bay, and can be commanderred there.
Looking for ideas on where to mount the remote, non-destructively of course. I'm really pretty sure that the bay is best for the changer.
Old Feb 19, 2003 | 05:06 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Default Re: CD Changer + Stock HU C4 (TerryMathews)
I mounted a Kenwood 10disc Mp3/CD changer in the cargo area, and keep the remote inside my console unitl needed.
The amplifier and electronics are in the passenger side storage tray hooked into the antenna leads.
Old Feb 19, 2003 | 05:12 PM
TerryMathews
Default Re: CD Changer + Stock HU C4 (biggrizzly)
How did you route the remote cable into the glove box (if that is where you are talking)?
Can I get a shot of the remote, and where it is hiding? Thanks!
Old Feb 19, 2003 | 06:51 PM
biggrizzly's Avatar
biggrizzly
Terry,
Here are two shots of the CD Changer's RFmodulator/control unit. I have it velcro'd on to the bottom of the plastic storage liner. I did not have to drill any holes ( This is why I routed the remote lead under the liner and over the edge of the bulkhead ). The wire lead then runs between my seat and the console. I just pop remote in the console when it is not in use. (or it falls on the floor under my seat :jester ) The console lid will close with the wire going into it without damaging the cable. Also the power and antenna connections are right below the plastic liner in my car (1994). The controler for the HU has all the connections you need right on it.
HTH
Don Haller
Aiken, SC
Old Feb 19, 2003 | 06:56 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
here's mine:
The HU isn't stock, but this is the same setup I had when it was...so the HU makes no difference... :D
Old Feb 19, 2003 | 08:45 PM
stinger95's Avatar
stinger95
Cruise-In IV Veteran
Time for some spring cleaning Mr Mojo. :yesnod:
Old Feb 19, 2003 | 09:13 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
moving to "Audio"
To CD Changer + Stock HU C4
