Sponsored by: Innova
Installing Amp While doing as Little Damage as Possible
Old Feb 21, 2003 | 04:40 PM
knesbitt's Avatar
knesbitt
Default Installing Amp While doing as Little Damage as Possible
I don't like the idea of drilling holes into my Vette. What is the best way to anchor my amp while causing as little damage as possible? I am doing a very simple setup so I don't need show quality displays.
Old Feb 21, 2003 | 04:42 PM
Kale's Avatar
Kale
Default Re: Installing Amp While doing as Little Damage as Possible (knesbitt)
lift carpet
put 3/4" mdf under carpet
mount amp THROUGH carpet to mdf.
Old Feb 21, 2003 | 04:44 PM
pdd000's Avatar
pdd000
i just cut a piece of partical board 12in wide by the width of the interior in the back and covered it with black carpet. then screwed the amps to it then i velcroed it down. works great for not much cake :cheers:
Old Feb 21, 2003 | 04:46 PM
Kale's Avatar
Kale
Default Re: Installing Amp While doing as Little Damage as Possible (pdd000)
Good luck, I hope it holds.
Old Feb 21, 2003 | 04:47 PM
knesbitt's Avatar
knesbitt
Do you or any body else have any instructions? I was actually thinking about putting it under or behind my seat. It is har to believe Velcro would hold. What happens in an accident?
Old Feb 21, 2003 | 04:49 PM
Kale's Avatar
Kale
The velcro becomes undone, and you've got a new skylight in your head.
just put board under the carpet and make a carpet sandwich. This is really the safest way to prevent it from behind a projectile... short of going THROUGH the car.
Old Feb 21, 2003 | 04:50 PM
knesbitt's Avatar
knesbitt
Default Re: Installing Amp While doing as Little Damage as Possible (Kale)
That amp would be a projectile in the slightest fender bender. Am I right?
Old Feb 21, 2003 | 04:53 PM
Kale's Avatar
Kale
With velcro? Hard to say. Some velcro will hold like glue, so I suppose it depends on how heavy the amp is. Im sure a 5mph fender bender wouldn't displace it.. but what if you rolled the car?
Old Feb 21, 2003 | 04:54 PM
knesbitt's Avatar
knesbitt
Hmmm. Is the particle or MDF fastened to the chasis in any way (Glue or Velcro under the carpet)? Or are the screws from the amp through the carpet holding it in place?
Old Feb 21, 2003 | 04:55 PM
knesbitt's Avatar
knesbitt
Yeah. But in a 25mph + accident that baby is airborn.
Old Feb 21, 2003 | 04:59 PM
knesbitt's Avatar
knesbitt
Is it easy to lift the carpet then put it back with creating too much of a disturbance. Ie rips & tears. Also where do I get MDF and how much? Also where is best place to find ground on 99 Coupe? I am implementing amp into BLOSE system to power stealthbox.
Old Feb 21, 2003 | 05:00 PM
Kale's Avatar
Kale
it would be a good idea to use some 2 sided mounting tape between the mdf and the floor of the vehicle. then carpet over the MDF, and screw the amp through the carpet into the MDF. If this is going under the seat, that's plenty. And make sure its MDF you use, and not particle board. It's really easy to pull screws out of particle board, but MDF is stronger.
<BLOCKQUOTE>code:<HR><PRE>
{-----AMP----}
---------------------- < - carpet
######### <- MDF
~~~~~~~~ < tape
--------------------- <- floorboard
</PRE>[/QUOTE]
I havent pulled the carpet out of a C5, but on my 86 vette, it was really easy and didn't tear at all. consider the age of the carpet, so i wouldn't be worried.
Be careful, don't force anything.
Any store with wood has MDF
[Modified by Kale, 2:04 PM 2/21/2003]
Old Feb 21, 2003 | 05:07 PM
knesbitt's Avatar
knesbitt
You are a big help. Thanks
Old Feb 21, 2003 | 05:38 PM
mrkln's Avatar
mrkln
I used 3/4" birch instead of MDF to cut down on weight and used silicone to attach the birch to the floor of the hatch. I then layed the carpet over it and mounted the amps through the carpet into the birch. :yesnod:
Old Feb 21, 2003 | 06:18 PM
dexter's Avatar
dexter
Default Re: Installing Amp While doing as Little Damage as Possible (mrkln)
Great idea!
Old Feb 21, 2003 | 08:51 PM
pdd000's Avatar
pdd000
wow maybe ill rip out the carpet and put the wood underneath :thumbs:
Old Feb 22, 2003 | 05:48 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Kale's right, for a simple setup, that's a good way of doing it. :thumbs:
To Installing Amp While doing as Little Damage as Possible
