Sponsored by: Innova
new alt
Old Feb 21, 2003 | 07:46 PM
pdd000's Avatar
pdd000
Default new alt
should i by a new alt. mines rated at 105 amp. the rf 1500bd draws 90 amps with regular music, but i also have the kicker amp. will this be to much for the stock alt :confused:
Old Feb 21, 2003 | 07:53 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: new alt (pdd000)
I would...
when you're looking for one make sure you go by the idle output and not just the max, cause some hi-output alts end up putting out less amps at idle than a stock alt.
Old Feb 21, 2003 | 08:02 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Actually your alt is rated at 110 amps. As for getting a new alt? It wouldn't be a bad idea with the power you're going to be pumping. Anything from a 140 to 200 amp alt should be sufficient. Remember to upgrade the Big-3. By upgrade I mean add to stock wiring, not replace. ANL fuses will be a necessity as well for both the alt to battery wire and the battery to amp wire. With the amps you have I would run at least 2-gauge wire for all power and ground. An Optima Yellow Top battery would by worth getting also. Use the top posts to connect all your aftermarket wiring and the side mounts for your stock connections.
Here's a link to check out some GM alts.
www.alternatorparts.com
Old Feb 21, 2003 | 08:04 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: new alt (The^Nomad)
:iagree: :thumbs:
Old Feb 21, 2003 | 08:18 PM
pdd000's Avatar
pdd000
i just bought a 140 amp alt thnkx for the info :smash:
Old Feb 21, 2003 | 08:30 PM
Metal Wulf's Avatar
Metal Wulf
what's it put out at idle ?
Old Feb 21, 2003 | 08:50 PM
pdd000's Avatar
pdd000
90-110 amps at idle
Old Feb 21, 2003 | 08:52 PM
Metal Wulf's Avatar
Metal Wulf
90-110 amps at idle
nice :thumbs:
Old Feb 21, 2003 | 11:53 PM
_Nomad_'s Avatar
_Nomad_
90-110 amps at idle
:thumbs:
Old Feb 22, 2003 | 08:57 AM
M396 #00-011's Avatar
M396 #00-011
Where did you get it? How much?
Old Feb 22, 2003 | 11:13 AM
pdd000's Avatar
pdd000
Default Re: new alt (M396 #00-011)
http://www.alternatorparts.com :thumbs:
Old Feb 22, 2003 | 11:18 AM
M396 #00-011
Thanks :thumbs:
To new alt
