Alpine iLX-507 feedback please
The Alpine iLX-507 seems to have all the features I am looking for. It costs a bit more than I wanted to spend because of the interface you need to make it fully compatible with the the chimes and steering wheel controls, etc. The interface the shop is quoting is $300+.
I plan to run it with the rest of the Bose system and see how that goes. I am primarily looking to get out from under the factory Bose unit.
I am looking for feedback from people that have one of these Alpine units.
Thanks!
https://www.crutchfield.com/p_541RP5...SAAEgJ7OPD_BwE
https://www.crutchfield.com/p_500ILX...e-iLX-507.html
Also, if you originally had the stock NAV system, the stock GPS antenna should plug right into the new Alpine system, so you won't need to use the one that comes with the Alpine. If you're also wanting to add XM radio, you'll need to purchase this additional tuner as the stock XM tuner can't be reused with an aftermarket head unit. https://www.crutchfield.com/p_220SXV...0V1-Tuner.html You can however reuse the stock XM antennas with the use of some adapters, this thread I wrote will lt you know what you need to do this. https://www.corvetteforum.com/forums...-xm-tuner.html
Another thing I reccomend while you're at it is to also add a backup camera, you'll be glad you did. Let me know if this helps, or if you have any other questions.
It's a great head unit with a sharp HD screen. I use the available BT volume **** option as it is a very nice convenience add-on
my 3LT had Nav with Bose no Onstar, I am using the RP5-GM11 without any isues. I have the little chime module mounted to the radio adapter mount and it is plenty loud to here in the driver seat. sounds decent enough so far.
One thing to note, use the 507 microphone, the OEM one int he car and several others caused echo issues..
Hereis how I mounted my iLx-507 Mic
I and others tried to use the stock mic with an aftermarket system, I couldn't get it to work with my Pioneer, so I mounted the Pioneer mic, up on the drivers side "A" pillar by the stock mic similar to what's shown above.
