Sponsored by: Innova
How do I bench test a head unit for power?
Old Feb 24, 2003 | 07:42 PM
gpagaduan's Avatar
gpagaduan
Default How do I bench test a head unit for power?
I can't get it to power up through the car. (And I don't have another car to test with) I know for certain that the power wires have power and that the thing was grounded.
Old Feb 24, 2003 | 09:02 PM
brianw21's Avatar
brianw21
Default Re: How do I bench test a head unit for power? (gpagaduan)
There are three wires that need to be connected to power up a head unit.
1. +12v
2. Switched 12v (Accesory)
3. Ground
Hook those up to a spare battery, or pop the hood and use jumper cables. If you have a spare PC power supply you could use that as well.
Then connect the speaker wires to a spare speaker, or RCA outs to a home stereo and away you go.
If you have a battery charger that would work as well.
-BW
Old Feb 25, 2003 | 01:19 AM
gpagaduan's Avatar
gpagaduan
Default Re: How do I bench test a head unit for power? (brianw21)
1. +12v
3. Ground
-BW
I don't have a spare battery. If I pop the hood and connect directly to the battery via jumper cables, do I connect both the +12v and the accessory wire to the positive post of the battery? (and ground to the frame, of course)
Old Feb 26, 2003 | 01:34 AM
Monster231's Avatar
Monster231
that would work, but put the negative to your battereis negative as well.
To How do I bench test a head unit for power?
