Sponsored by: Innova
Stereo Replacement
Old Mar 1, 2003 | 11:29 PM
3j's Avatar
3j
Default Stereo Replacement
I have an 84 and the Bose Stereo is not working properly, channels dropping at will, static sometimes, etc. What is a good replacement with CD that will fit in the hole properly?
Old Mar 1, 2003 | 11:37 PM
bogus's Avatar
bogus
Default Re: Stereo Replacement (3j)
replace everything.
the channel drops are dying amps.
just about any DIN radio will fit. Metra makes a kit.
Run new wire to the speakers.
The bose system is so propriatary that there is little you're gonna do with it. The speakers are wack, 1 ohm, I think, the amps are wack... ick-poo.
just replace everything.
you will more than likely need more detailed info, and if I was a mod, I would move this over to the Audio/Electronics section under General Corvette Topics.
You should reask this question over there, unless a mod sees this and moves it first!
Old Mar 2, 2003 | 09:20 AM
8686corvette's Avatar
8686corvette
Irecommend a good Sony Explode system, looks great in mine :auto:
Old Mar 2, 2003 | 01:13 PM
bogus's Avatar
bogus
Default Re: Stereo Replacement (8686corvette)
shiver.
I could not, with clear conscience, recommend the Xplode line of products.
They have a dubious reputation for durability and the sound quality ain't all that. They do hit hard, tho, but that is not enough for my ears.
Check my sig for the system in my Vette. It is not done... never will be more than likely... :D
There is a happy medium between Xplode and what I have...
as I said, run this thread over to the Audio section, you will get some very good additional advice.
Old Mar 2, 2003 | 01:16 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
moving to "Audio"
Old Mar 2, 2003 | 01:57 PM
Metal Wulf's Avatar
Metal Wulf
stay away from Sony !!
To Stereo Replacement
