Sponsored by: Innova
2 or 1 8inch Subwoofer(s)?
Old Mar 11, 2003 | 09:19 PM
Light84vette's Avatar
Light84vette
Default 2 or 1 8inch Subwoofer(s)?
Should I get two Subwoofers or one? IF I get say 2 8inch subwoofers, how big does the box have to be to hold it? Like 1 cubic foot or something? Also does that space need to be ventelated somehow with like a hole in the side or something like that? Please give me some help, I plan on redoing my entire stereo system and I need some advice :confused:
Old Mar 11, 2003 | 09:58 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: 2 or 1 8inch Subwoofer(s)? (Light84vette)
I'd go with 2 :thumbs: box size will be determined by what the speakers requirements are, but 1 cube is about right.
I'd recommend going with the E8A, you can check it out here: http://www.edesignaudio.com/ep/overviews/8aoverview.htm
Old Mar 11, 2003 | 10:14 PM
Light84vette
Default Re: 2 or 1 8inch Subwoofer(s)? (Metal_Wulf)
So If I go with 2 8inch subwoofer then I would need 1 cubic feet of inner room for both of the speaker put together? LIke if I made a box that had both of the speaker in it and then I would only need 1cubic foot of volume? :confused:
Old Mar 11, 2003 | 10:20 PM
Metal Wulf's Avatar
Metal Wulf
I'm using the E8A as an example... for 2 of them you'd need 0.5ft^3 for a sealed box, for a ported box you'd need 1.0ft^3. And that's internal volume after speaker displacement.
Old Mar 11, 2003 | 10:21 PM
Metal Wulf's Avatar
Metal Wulf
Also... Do you have any ideas for the rest of your system like HU, comps, amps ?
Old Mar 11, 2003 | 10:24 PM
Light84vette
I was thinking of getting a Kenwood MP3/CD player Head unit, but I also have two 175 watt 6x9's, but I'm clueless on amps.
Anyway what is better sealed box or ported? Is it easier to make on or the other? :confused:
Old Mar 11, 2003 | 10:31 PM
Metal Wulf's Avatar
Metal Wulf
Generally for SQ you go sealed and for SPL you go ported.
Sealed are easier to make, but niether one is that hard. Once you figure out what you want... then we can go from there.
You really won't need those 6x9's either.
Old Mar 11, 2003 | 10:36 PM
Light84vette
Why wont I need them? They are already installed? I bought the car and the previous owner had 2 6x9's in the back, a kicker and an amp with it all. But the amp broke and the HU is a tape player. So I decided I would chang all that and go with a new amp and I might as well go with 2 8 inch subwoofers.
Also what does SQ stand for? and what about SPL? :confused:
Old Mar 11, 2003 | 11:14 PM
Kale's Avatar
Kale
SQ = sound quality
SPL = sound pressure level
you can actually have both. But with a tight budget, it's one or the other.
i would go with one e8a and 400 watts for it, with a CDT HD component set up front, with 100 watts per side.
Old Mar 11, 2003 | 11:18 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: 2 or 1 8inch Subwoofer(s)? (Kale)
yep, go with one, especially if you plan on leaving the 6x9s in.
Old Mar 11, 2003 | 11:48 PM
Lord Odin's Avatar
Lord Odin
I've been told you could manage to fit 2 10's back there. I'm thinking about doing that with mine because the 6x9's just don't have the punch I'm looking for. Maybe throw in two 10's and a set of tweeters as well. That should do you nicely. :thumbs:
Old Mar 11, 2003 | 11:51 PM
Kale's Avatar
Kale
Default Re: 2 or 1 8inch Subwoofer(s)? (Lord Odin)
a couple of E10k's at 400 watts each from edesignaudio.com would definately turn your eardrums inside out.
Old Mar 11, 2003 | 11:52 PM
Metal Wulf's Avatar
Metal Wulf
throw tweeters where :confused:
Old Mar 12, 2003 | 12:15 AM
Lord Odin's Avatar
Lord Odin
Heck if I know. I'm just repeating what I was told. :yesnod:
Old Mar 12, 2003 | 12:23 AM
Metal Wulf's Avatar
Metal Wulf
umm...okay then...
Old Mar 12, 2003 | 12:53 AM
Light84vette
I just took my vette out for a drive a couple of mins ago and the Radio would turn on and off, like be loud and then when I go over a bumb or close the door hard, it turns all low again. Well It isnt in the wiring which I checked a while ago. Its the freaggin Head Unit, it turns low and then when I smack it, it comes back on. Pile of smelly heap, I should throw this crappy tape player out and get a CD player. But SHould I get an MP3/CD player or just a CD player?
I heard you could store like 160+ songs on a MP3 disk. But what if you want a song thats is say for example in the 100's. Would I have to skip 100 songs just to get to it?? Thats insane :confused:
Old Mar 12, 2003 | 12:59 AM
Metal Wulf's Avatar
Metal Wulf
well it's more like 120 songs or less depending on the bitrate of the encoding. Anyways... when you make the disc you can put songs into seperate directories or folders to sort them out, so then you look for a track that way and it cuts down the time.
To 2 or 1 8inch Subwoofer(s)?
Old Mar 12, 2003 | 01:09 AM
Light84vette
Also should I do the install my self or let Best Buy do it? I dont know about best buy, my firend got his install and they charged an extra 50 bucks on top of the free install and this 50bucks was after the harness kit and the other kit that makes the HU go back and be flush with the dash
Old Mar 12, 2003 | 01:26 AM
Metal Wulf's Avatar
Metal Wulf
Always do it yourself :thumbs:
Old Mar 12, 2003 | 01:29 AM
Light84vette
Have you done your by yourself? How long does it take? How man wires are there to hook up? :confused:
