Sponsored by: Innova
Which amp would you use>>
Old Mar 20, 2003 | 10:13 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Which amp would you use>>
I have 2 older amps.. an A/D/S PH12, 6 channel, 23 watts per channel NON_bridgeable or an ORION HCCA 225, 2 channel, 25 watts per (at least rated at that)
I will be running 6.5" midbass/bass in the back and 5.25 with tweets in the front..
Old Mar 21, 2003 | 12:46 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: Which amp would you use>> (-=Jeff=-)
Orion :cool: :thumbs:
Old Mar 21, 2003 | 07:48 AM
Mark1376's Avatar
Mark1376
Default Re: Which amp would you use>> (Metal_Wulf)
:iagree:
Old Mar 21, 2003 | 09:57 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Which amp would you use>> (Mark1376)
Cool, I have the Orion in the car now.. I got the A/D/S for free too.. If it was bridgeable I would use the A/D/S..
Now where can I get good passive crossovers (mainly to use for 120hz down)?
To Which amp would you use>>
