Sponsored by: Innova
92 Bose w/CD
Old Mar 23, 2003 | 01:01 PM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default (@ Bose w/CD
Recently the CD protion of the Bose Gold system has quit playing. Am I better off by buying a total replacement system or taking my system out and having it rebuilt? Any advice on de-installation (and, of course, installation) procedures/processes will be gratefully accepted. Also, I beleive that I will need to replace the front Bose speakers as the left side has less output than the right unless the volume is turned up to "War Alert" stage.
Old Mar 23, 2003 | 01:03 PM
GentleBen's Avatar
GentleBen
Default Re: (@ Bose w/CD (GentleBen)
My apologies for the abyssmal typing. That should be "92", not (2 for the year.
Old Mar 23, 2003 | 01:48 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
IMHO...you'll be better off having the CD player serviced/replaced rather than the whole Blows unit. Had problems with mine a few years ago and a local electronics shop replaced the player portion for less than $100, including servicing the cassette player.
So far as the removal/installation...check the archives. I found good directions there. ;)
Old Mar 23, 2003 | 08:19 PM
bogus's Avatar
bogus
the bose systems seem to die, on cue, at the 9th year of existance.
A repair will ulitmatly cost about 500.00... head is about 175-200, the amps are 50.00 to 100.00 each.
most of the time, a capacitor goes bad on the amp. it will blow up, then spread goop all over the circuit board. ick.
here is my take:
The head units are junk. The speakers are junk. The amps are junk. That about sums it up. :)
The speakers themselves are not very good. they use a basic paper cone speaker driver that does not really hold up very well over time. sad to say.
the amps are wierd. the system runs at 1 ohm stable - or something close to stable - it makes for a small, low power amp that can produce tons of power.
I am not impressed.
Check my sig for the system I installed.
you may or may not want to go to that extreem, but the options exist. For a small investment, $450.00 or so, you can get a nice little aftermarket system that will kill anything that the bose can do.
To 92 Bose w/CD
