Radio Amplifier Relay Location
The electrical service manual shows an amplifier relay in the circuit. Can anyone tell me where this realy is located? :banghead: :banghead:
:cheers: :cheers:
:flag
D.orange. You could get a relay on line for about 10/12 bucks or right from chevy for $16.00 :flag
Now do I remove the radio to get at it or the A/C Heater controls below the radio or the DIS above the radio or all three? :confused:
No matter how much room it looks like you have, EVERYTHING is hard to get at! :yesnod:
Thanks a lot :cheers:
:flag
:seeya
controls the radio & the ugly bump on the passenger side of the dash, it took him about
hour & a half and he said he has done it many times before. I do not think you would have a hard time doing it at home. I farmed it out because I have a messed up eye (took a head shot in nam) and have a hard time getting my right to focus when I do close up work.
I did find a local radio shop who said he could do it in a half hour for $150.00 but his technician looked like Charles Manson & was stoned so I did the dealer bid. dealer charged $165.00 but he did nice neat work. good luck!! :flag :flag
Thanks again for the info. :cheers:
:flag :flag
:seeya
I could not get the "bump" off. I could not get the carpet section of the passenger's knee area out. There are two screws that screw into the bottom of the two metal straps that are part of that "bump".
After taking the whole dash apart and changing that relay, the radio works for about 5 minutes then it cuts out. Time for a new unit.
That was one pain in the butt!
Thanks for all of your help. At least I have a new amp relay installed. The old one was shot. It had leaked over its wires at the connector.
Why would anyone use two bolts to hold that relay onto the bracket that it is attached to is beyond me.
For what it's worth, there's flasher there too. There's one behind the DIC along with the horn relay. I think that's the hazard flasher. The second one is behind that bump to the left side and the only way to get at it is to either remove that bump which I can't do or take the dash pad off which is pretty easy. So if your flashers ever quit working and the one above the radio behind the DIC works then you'll know where the 2nd one is located.
Thanks again for your helpful info. Now to find a radio that looks good and half way matches the rest of the dash...
:flag :flag
:seeya
he was very helpfull . I paid $325.00 . you could also send him your radio & he will rebuild
it. :cheers: :cheers:
