Originally, my box is about 1.3 cu ft. Now, after reverve my sub, I can only got about 0.8 cu ft and it sounds not as loud as it used to be but tighter.
This poly-fill stuff will keep the air and will make the sub thinks it's bigger box.
Has anyone used it? Does it help?
Thanks :cheers:
also, do not buy it from crutchfield, the cheapest place is walmart.
Go to the craft section and look for a bag that says "polyfil" it is less than $2 for a one pound bag.
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Re: Poly-Fill Stuffing (mike76002)
Thanks :cheers:
[Modified by mike76002, 4:55 PM 3/28/2003]
[Modified by mike76002, 7:18 PM 3/28/2003]
Yes, it does work and you will hear a difference depending on how much Pollyfill you put in it. It's a trial and error kind of thing, just put enough in till it sounds like you want. Get it at Wal Mart, it's cheaper there.
