Sponsored by: Innova
Need Ideas for Amp Rack.
Old Mar 30, 2003 | 05:33 PM
knesbitt's Avatar
knesbitt
Default Need Ideas for Amp Rack.
What is the best way to anchor an MDF board holding amps to the rear hatch area WITHOUT drilling? I have removed carpet and cut MDF board that accommodate amps. I plan to place MDF under carpet then put amps on top carpet and then drill through carpet and and wood. I just need some way of securing the MDF to the fiberglass body. I bought some silicone sealant with hopes that it would be strong enough to hold the MDF to the body. I just want some ideas before I proceed. If anyone has a better wat to anchor MDF to rear compartment without drilling please sound off.
Old Mar 30, 2003 | 06:40 PM
Tolofou's Avatar
Tolofou
Default Re: Need Ideas for Amp Rack. (knesbitt)
window sealant.. Gooey rubber that is great for any stick to jobs and has some dampening matter..
Rob
Old Mar 30, 2003 | 07:39 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Yes, the silicone or acrylic caulk will hold it. If you want a real strong bond try liquid nails (AKA construction adhesive).
Old Mar 30, 2003 | 07:56 PM
knesbitt's Avatar
knesbitt
Default Re: Need Ideas for Amp Rack. (The^Nomad)
How hard is it to remove liquid nails if I wanted to sell my car?
Old Mar 30, 2003 | 10:58 PM
bogus's Avatar
bogus
not easy.
use silicon.
Old Mar 30, 2003 | 11:18 PM
_Nomad_'s Avatar
_Nomad_
Very hard, with a chisel. Silicone is much easier to remove. ;)
Old Mar 31, 2003 | 09:51 AM
lotzahp's Avatar
lotzahp
That's probably the best way to do it, and I would use silicone instead of LiquidNails.
Also, if you were gonna use one sheet of MDF under the carpet, it may create too big of a bulge under the carpet - especially 3/4".
A different idea is to cut strips of MDF the size of the recesses in the fiberglass body pan, and secure them with silicone. Then you could secure a very thin sheet to them and mount your amps. It makes the carpet bulge less.
Old Apr 1, 2003 | 01:41 AM
Butters00Vet's Avatar
Butters00Vet
how big are the amps and how many?
To Need Ideas for Amp Rack.
