Sponsored by: Innova
Antenna mast '88
Old Mar 30, 2003 | 08:33 PM
L.R.Payne's Avatar
L.R.Payne
Default Antenna mast '88
I purchased a mast kit from Ecklers and followed the directions in the package. I used the "tool" to remove the washer but from there on I can't get the old mast out. I know that to remove the whole antenna I need to go through the wheel well but I thought I just need to change out the mast which I could do from the top. I can hear the motor working when I turn the radio on and off. BTW the radio is a new Pioneer. Any ideas are appreciated.
Old Mar 30, 2003 | 11:21 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: Antenna mast '88 (L.R.Payne)
In order to replace the mast you have to remove the antenna motor. In order to remove the motor you have to go up under the fender well to get to it.
Bummer, I know. :(
Old Mar 31, 2003 | 06:40 PM
Tolofou's Avatar
Tolofou
Default Re: Antenna mast '88 (The^Nomad)
You guys must have skinny arms.. There is no way I am able to stick my hand let alone my whole tree trunk arm..
The wheel well is probly the way to go.. What a location..
Any pics of others? Mine might be changed..
Rob
Old Mar 31, 2003 | 09:14 PM
L.R.Payne's Avatar
L.R.Payne
Default Re: Antenna mast '88 (Tolofou)
That was what I was afraid you-all would say, so I'll problbly take the car apart and then for get how to put it back togather......senior moment. thanks.
Old Apr 2, 2003 | 03:24 AM
_Nomad_'s Avatar
_Nomad_
Don't feel too bad, I too have to change out my antenna on my '88 35th Anniversary Edition. What makes it even worse is that I broke it myself. I bent it while working in the hatch area. Talk about a DOH! :rolleyes: :mad :(
Old Apr 2, 2003 | 09:10 AM
JDF's Avatar
JDF
I replaced my '88 mast last summer. This is really pretty eaisy job. Disconnect the electrical and ground, leave the antenia wire alone, disconnect the mounting brackets. Take the unit apart while the antenia wire is still connected to the car (this means you are working on your antenia unit under the rear of the car, you do not have to take the inner fender off) and replace the mast, then reinstall. This is maybe a 2 hr. job, but I am slow.
Old Apr 2, 2003 | 08:11 PM
L.R.Payne's Avatar
L.R.Payne
Default Re: Antenna mast '88 (JDF)
Thanks, if it took you 2 hours, it will take my a year...I tend to procrastinate, or so my wife tells me daily...... :D
To Antenna mast '88
