I see where the cable is hooked to the antenna motor and see it plugged under the rear carpet but from there to the front where the head unit is.. I spent awhile yesterday on looking to get to the antenna cable out from the Bose unit installed way into the dash.. I got everything wired except the antenna cable to plug into the back of my deck.. Please help.. Shold I just run a new antenna cable?
the original antenna wire is located at the reciever not the head unit. In my 94 it was located behind pass. seat in the storage bin. Not sure if it is in the same location as your 91 but am sure that the antenna wire is located at the reciever.
The storage bin behind the pass seat is empty and only is carpeted.. I see a unit behind the Headunit that looks like the receiver unit.. I tried to get to it but so much has to be removed to get to it..I am going to look for a replacement at i can use instead of looking for the old one..
on the 91 the head unit just controls the reciever box which is up behind the passenger side glove box. thats where you ant wire is plugged into. and its a pain in the rear to get at! gd luck
