Sponsored by: Innova
What thickness of MDF?
Old Apr 8, 2003 | 07:15 PM
battsup's Avatar
battsup
Default What thickness of MDF?
What size should i use? I am going with 2 10 inch subs(probably some cheap clarions for now). The whole box is going to be 2cu feet (2x1x1). The local home depot has either 5/8 thickness or 1/2 inch thickness. I do not want to go to heavy just enough for some good bass.
Old Apr 8, 2003 | 07:40 PM
Tolofou's Avatar
Tolofou
Default Re: What thickness of MDF? (battsup)
A good box is always 3/4 MDF.. Might be heavy but will last and sound great..Get a sheet and start cutting.. I had built a custom box for 2 12" woofers and me and a friend to carry it I allso had 3/4" plexi on the front and sounded killer...
1/2 is chezzy but will work and be light..Carpet it and nobdy will know..I have seen some make these boxxes.. But why waste time and money if you are going to upgrade your speakers I would think you want to keep it for long time so get the best now..
But I think you know what you want allready...
Rob :D
Old Apr 8, 2003 | 09:08 PM
battsup's Avatar
battsup
Default Re: What thickness of MDF? (Tolofou)
So should i buy the 5/8th or 1/2 inch?
Old Apr 8, 2003 | 09:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you're dividing the box in half (one compartment for each sub), for that size box 1/2" should adequate. If you're making one big box with no divider or bracing, I'd go with the 5/8".
:cheers:
Old Apr 8, 2003 | 10:02 PM
bogus's Avatar
bogus
3/4". I would not recommend anything less with that much sub.
If you have to go less, get the 5/8"... but I would use 3/4".
Old Apr 8, 2003 | 10:41 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: What thickness of MDF? (bogus)
go to a different store and get 3/4"
do it right or don't do it at all...
also 2 cubes sounds like to much volume for a pair of 10s, did you think about specs or are you just throwing a couple speakers in a box ?
[Modified by Metal_Wulf, 10:42 PM 4/8/2003]
Old Apr 8, 2003 | 11:03 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: What thickness of MDF? (Metal_Wulf)
Well you can get by with 5/8" then coat the **** out of the inside with rubberized undercoating. the coating will actually strengthen the box and also still allow to flex.
10's should only need anywhere from .4 - .8 cubic feet, normally for a sealed cabinet. A ported or bandpass may require the larger volume :steering:
Old Apr 8, 2003 | 11:41 PM
battsup's Avatar
battsup
that was what i was doing. time to do some research i guess
Old Apr 8, 2003 | 11:42 PM
Zdamon1's Avatar
Zdamon1
:iagree:
I don't care what subs you are putting in the box especially 10's.
Old Apr 9, 2003 | 11:00 AM
Jim85IROC's Avatar
Jim85IROC
Default Re: What thickness of MDF? (JoeyG)
Exactly. Use 3/4" and brace it.
Old Apr 9, 2003 | 09:22 PM
kittmaster's Avatar
kittmaster
Default Re: What thickness of MDF? (Jim85IROC)
:withstupid:
To What thickness of MDF?
