Sponsored by: Innova
Amp Upgrade
Old Apr 12, 2003 | 11:18 PM
Snowwolfe's Avatar
Snowwolfe
Default Amp Upgrade
A member of this forum was kind enough to tell me I am probably blowing my rear speakers because of loud music and not a very good amp in the stock Bose system. What can I do to upgrade the amp? I dont need a killer system. I just want something to enjoy some good classic rock at a nice volume level without listening to distortion and lots of speaker static. I am not a lover of deep booming bass either. I plan on buying a new C6 so I dont want to spend a ton of money. I did order another pair of rear speakers (same type). What can I do with $750 to upgrade my stock amps? Is it easy for me to do myself?
Also, most of the music coming from my system is biased to the front. When I set the fader to enjoy more from the rear I have to increase the volume control quite a lot to have a balanced sound. Is this normal?
[Modified by snowwolfe, 4:18 AM 4/13/2003]
[Modified by snowwolfe, 4:19 AM 4/13/2003]
[Modified by snowwolfe, 4:24 AM 4/13/2003]
Old Apr 14, 2003 | 12:34 AM
CarbonTuning's Avatar
CarbonTuning
Default Re: Amp Upgrade (snowwolfe)
JL and Phoenix Gold make some nice amps for the money. If you want to spend a little bit more check out PPI and Zapco.
sounddomain.com
infinatecaraudio.com
sounddomain.com
thezeb.com
cbrstereo.com
Jordan
Old Apr 14, 2003 | 05:20 AM
kumar75150's Avatar
kumar75150
Default Re: Amp Upgrade (Nghtmre)
Personally, I would also replace the front door speakers with Infinitys and get a decent 4 channel amp. All that can be had for around 500 dollars.
Old Apr 14, 2003 | 01:11 PM
Snowwolfe's Avatar
Snowwolfe
Default Re: Amp Upgrade (kumar75150)
Can I add the amp to the bose? What Infinitys did you use up front?
To Amp Upgrade
