Sponsored by: Innova
JVC head unit/BOSE speakers
Old Apr 17, 2003 | 08:25 PM
efweber's Avatar
efweber
Default JVC head unit/BOSE speakers
My 1984 has original Bose speakers and amps, but an aftermarket JVC head unit. All speakers sound terrible, and I am blowing the clock/courtesy light fuse daily. I believe I need to replace the speakers/amps. I need to know the following: Do I need to replace the wiring from the head unit to the speakers? Do I need to build new boxes, or are there speakers that will fit my stock openings? ANY help is greatly appreciated!
Old Apr 17, 2003 | 09:11 PM
stanandsue's Avatar
stanandsue
Default Re: JVC head unit/BOSE speakers (efweber)
You have to replace the speakers. I put a new Clarion unit in last weekend and ran new wires directly to the Blose speakers - bypassing the local amps. Then I read another thread that said Blose speakers are 1 ohm impedance while most systems drive 4 ohms. I have 40 Watts x 4 channels, with a 15 amp fuse, so if fade and balance are neutral, I can't overdrive them too much. But if dialed to just one speaker, 40 Watts in 4 ohms give 3 amps, but into 1 ohm it give 6 amps :mad . I replaced them tonight with 4 ohm units. Wal-Mart has a good size selection of JVC and Pioneer speakers, and it didn't take long since I had already run new wires and the connectors were the same. I had to drill new mounting holes in the plastic, but that was easy. It sound's good. Good luck. :seeya
