Sponsored by: Innova
C5 - Replacing cassette head unit with CD head unit
Old Apr 19, 2003 | 08:30 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
Cruise-In IV Veteran
Default C5 - Replacing cassette head unit with CD head unit
I am going to be installing the Delphi XM reciever in my car soon. I currently have the BOSE system with the cassette head unit and factory CD changer. I want to remove the changer, switch to a CD head unit, and use the CD changer input as an aux input (using a Logjam electronics adapter) for the XM.
Is this a reasonable plan, and is the CD head unit a direct swap for the cassette head unit?
Old Apr 19, 2003 | 11:58 PM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: C5 - Replacing cassette head unit with CD head unit (70L46)
....and is the CD head unit a direct swap for the cassette head unit?
:yesnod:
Old Apr 20, 2003 | 10:36 AM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Default Re: C5 - Replacing cassette head unit with CD head unit (Conquer)
Thanks! :cheers: :cheers: :cheers:
Old Apr 24, 2003 | 08:23 AM
C5Steve's Avatar
C5Steve
If you encounter problems, you should check the archieves for imput from
"99HT" . No-0ne knows even half of what he does about the C5"s stock cassette/CD stereo systems. Good luck
To C5 - Replacing cassette head unit with CD head unit
