Sponsored by: Innova
Help--Problem with Alpine HU and/or PAC OEM1 setup working!
Old Apr 22, 2003 | 10:06 PM
DSTJ99's Avatar
DSTJ99
Default Help--Problem with Alpine HU and/or PAC OEM1 setup working!
I installed an Alpine 7892 in my car two weeks ago and after driving the car a lot this weekend and setting up my preferences with the CD player i realized that there is a BIG problem. Here it is::confused:
I have the PAC OEM1 connected to power the stock speakers with the Alpine. When I am using the tuner I'm getting all 6 speakers working fine. (The front 3.5" twiddler, the 7" Bose woofer, and the rear 6.5" twiddler). HOWEVER, when I play a CD-- the Bose 7" woofer is not working. Its playing nothing at all. So, my sound is flat and without bass. This is also true when I use my iPod through the aux input. BUT, its fine with the tuner!!!:crazy:
What the heck could be causing this problem?? It sounds like an Alpine issue to me. All parts are brand new and installed by myself. I took caution in affirming every connection and putting all back together. Any suggestions?
I am going to email tune town as well.
Old Apr 23, 2003 | 11:58 AM
leolufse's Avatar
leolufse
Default Re: Help--Problem with Alpine HU and/or PAC OEM1 setup working! (DSTJ99)
I had the exact same issue with my 7892 when using the OEM1. There was no problem when listening to FM, but once I switched to CD, the 7" bose woofer didn't put out nearly as much bass (if at all) as it did with FM.
I know that one of the power leads on the OEM1 is labled wrong. What is happening is that when you are listening to FM, there is power to the FM antenna wire that will switch on the Bose amps. But when you are listening to CD, there is no power to the antenna wire and the Bose amps are not turned on.
Try to change the "power on" wire to the OEM1 from the antenna wire to the remote power wire. In other words, switch the blue/white wire with the blue wire.
Let me know if that works.
:cheers:
[Modified by leolufse, 12:03 PM 4/23/2003]
Old Apr 23, 2003 | 12:32 PM
DSTJ99's Avatar
DSTJ99
Default Re: Help--Problem with Alpine HU and/or PAC OEM1 setup working! (leolufse)
I'll try that, thanks. :thumbs:
Old Apr 24, 2003 | 09:02 AM
Conquer's Avatar
Conquer
St. Jude Contributor
.....In other words, switch the blue/white wire with the blue wire.
:iagree: If you notice, the blue/white wire on the PAC goes to the plug but does not come out the other end.... you need to make that connection.
Old Apr 27, 2003 | 03:38 PM
DSTJ99's Avatar
DSTJ99
Default Re: Help--Problem with Alpine HU and/or PAC OEM1 setup working! (Conquer)
Switched the wires- works perfrectly now!! Thanks guys. Sounds pretty good for stock speakers. Definately needs a tweeter though! :yesnod:
Old Apr 27, 2003 | 08:30 PM
Conquer's Avatar
Conquer
:cool:
Old Apr 28, 2003 | 02:17 PM
leolufse's Avatar
leolufse
Glad to hear. An easy way to add tweeters to the doors is to buy a set of 3.5" two-way speakers. They will bolt right into the stock Bose housing. They run from the deck power and won't inpact your OEM1 or Bose woofer output if you change them out.
:cheers:
Old Apr 28, 2003 | 02:24 PM
aurik's Avatar
aurik
Cruise-In IV Veteran
Elite Member
So *that's* what happened to my bass response after I swapped out my HU...
Old Apr 28, 2003 | 06:11 PM
DSTJ99's Avatar
DSTJ99
Glad to hear. An easy way to add tweeters to the doors is to buy a set of 3.5" two-way speakers. They will bolt right into the stock Bose housing. They run from the deck power and won't inpact your OEM1 or Bose woofer output if you change them out. :cheers:
Thats what I am toying with now, but I was planning on getting components and an amp. The Bose don't sound that bad actually. Especially during CD playback. The Alpine HU is really clear. We will have to see how long this goes for.....
[Modified by DSTJ99, 6:14 PM 4/28/2003]
To Help--Problem with Alpine HU and/or PAC OEM1 setup working!
