Sponsored by: Innova
fiberglass
Old May 17, 2003 | 08:37 AM
luck38's Avatar
luck38
Default fiberglass
looking to start using fiberglass for a custom interior, but have never used it before. Are their any good books, websites, videos etc. I want to create custom door panels, center counsel, and eventually a custom dash.
Old May 17, 2003 | 10:07 AM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: fiberglass (luck38)
This link has what you need. Look under "instruction videos"
http://www.selectproducts.com/frameindex.htm
Good luck! Fiberglass is great once you learn how to apply it. Practice before you jump into a big job like that. :)
Old May 17, 2003 | 01:12 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: fiberglass (Conquer)
Like said above, if it's your first time with fiberglass, start off with something small and practice. If it doesn't turn out how you like it, trash it and start over. It's lots of fun making your own custom stuff though :cheers:
Here's the sites I get all my crap from:
http://www.shopmaninc.com/
http://www.fiberglast.com/
Old May 18, 2003 | 11:08 AM
luck38's Avatar
luck38
thanks,
paul
Old May 18, 2003 | 02:58 PM
Metal Wulf's Avatar
Metal Wulf
make you post your progress, we'd love to see how you make out :thumbs:
Old May 20, 2003 | 08:49 PM
luck38's Avatar
luck38
when i make some progress i will post, fortunately for me i may be able to receive the materials at cost, i run a computer/electronics/car stereo business out of my home and am applying for an account with select products, if i get it i will post and let you guys know how much i can get off of their products, then pass on some savings to the forum members :cheers:
Old May 20, 2003 | 08:58 PM
Metal Wulf's Avatar
Metal Wulf
that would be sweet :thumbs:
Old May 23, 2003 | 03:21 AM
vrumvrum's Avatar
vrumvrum
Mixing the resin is the most complicated because of temp variations and time of year. I halfway recall some sort of "working with fiberglass" article in maybe Popular Hot Rodding or such. One of the tricks he used was to mix a "test batch" to time the cure of the resin. If it took too long or too short he would then readjust the amount of hardener to get the appropriate cure time.
Good luck
To fiberglass
