Sponsored by: Innova
I need a 6 3/4" sub. Do they exist?
Old May 18, 2003 | 02:58 PM
1COOLPC's Avatar
1COOLPC
Default I need a 6 3/4" sub. Do they exist?
I don't want to put a sub box in my Camaro but I do have spots in the back for two 6 3/4"" drivers. They would be free air. Do any drivers exist that would make a decent facsimile of bass output? I'm going to put some 6 3/4" Pioneer co-ax in my door holes so I would need these small subs to handle the bass end of things. Suggestions?
Old May 18, 2003 | 03:54 PM
Kale's Avatar
Kale
Default Re: I need a 6 3/4" sub. Do they exist? (1COOLPC)
My turn to help you out.. If you want some decent bass, and awesome sound... Try Adire Koda drivers... They are probably the most slammin' 6" drivers around... Put this comp set in your doors with about 150 watts per side.
http://adireaudio.com/mobile_audio/c...components.htm
Also, Focal makes a 5" subwoofer called the 5ws... 2 will be about as loud as a single 8 (read: not very loud) and they are expensive and require a .3 ported enclosure.
Old May 18, 2003 | 04:13 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: I need a 6 3/4" sub. Do they exist? (Kale)
Koda :D :yesnod:
Old May 18, 2003 | 06:01 PM
1COOLPC's Avatar
1COOLPC
Can I just get a Koda 6.75" wooofer Kale?
Old May 18, 2003 | 06:05 PM
Metal Wulf's Avatar
Metal Wulf
yes
http://adireaudio.com/mobile_audio/drivers/koda_6.htm
Old May 18, 2003 | 06:07 PM
1COOLPC's Avatar
1COOLPC
Default Re: I need a 6 3/4" sub. Do they exist? (Metal_Wulf)
Those look nice. I'll try to find a shop with a set I can listen to. Thanks Kale.
Old May 18, 2003 | 06:12 PM
1COOLPC's Avatar
1COOLPC
Kale, you have any suggestions for the below threads I posted on this other forum?
http://www.caraudioforum.com/vbb2/sh...&postid=999462
and
http://www.caraudioforum.com/vbb2/sh...hreadid=141501
[Modified by 1COOLPC, 3:12 PM 5/18/2003]
Old May 18, 2003 | 06:15 PM
Kale's Avatar
Kale
US Acoustics makes a good inexpensive amp, and they have a great warranty http://www.crutchfield.com
I agree with that guy though, ditch the rear speakers. Just run a single set of nice 6.5 components. I dont think you will find a store with Kodas, your best luck is to search for "Koda review" The general consensus on the set is "OMG!"
You need a line level converter to use the stock HU... not too familiar with those, always bought a new hu.
Old May 18, 2003 | 06:17 PM
1COOLPC's Avatar
1COOLPC
OK, rear speakers are mostly for when I pop the hatch at the beach or something. I'll figure something out there.
I was looking at those amps and they may work out just fine.
Old May 18, 2003 | 06:28 PM
1COOLPC's Avatar
1COOLPC
Kale,
Profile subs decent?
I can get a 300w x 1 for $149 but I can run it into both 6.75" woofers at a 2 ohm load and get 420 watts. Has a built in variable crossover.
I can get a 200w x 2 for $179 and run both the rear 4" and front separates at a 2 ohm load and get 300 watts x 2. Also has a variable crossover.
Seems like a good deal and both amps are kind of smallish.
I just don't want any noise added by using a cheap amp. Is Profile junk?
Old May 18, 2003 | 06:31 PM
Kale's Avatar
Kale
Profile amps are kind of shady... JBL are better if you just want a cheap subwoofer amp. http://www.ikesound.com takes a long time to ship, but they have great prices on JBL. Dont expect great reliability out of a JBL, though. I think like, 10% of owners have had problems. But thats still a lot better than Profile.
The only seperates I knwo of that run at 2ohms are the Image dynamics Chamelons... Kodas are 4 ohm.
You can get just the koda mids, but youre cheating yourself out of it by not getting the whole thing. Sandt38 can hook you up with those (He's on CAF)
Personally, Id stick to US Acoustics or Clarion amps http://www.mmxpress.com
[Modified by Kale, 3:34 PM 5/18/2003]
Old May 18, 2003 | 06:34 PM
1COOLPC's Avatar
1COOLPC
If I run rear fill speakers along with the front separates I will be at 2 ohms per channel provided I use 4 ohm drivers at all corners which I for sure will be.
The the subs will be a single 2 ohm load when wired in parallel so I need a good 2ohm channel of power for that. I need 3 channels of power at 2 ohms.
Thanks for the heads up on Profile.
Old May 18, 2003 | 06:36 PM
Kale's Avatar
Kale
yeah you can do that as long as you dont care about using your fader.
A single koda set will be louder than 4 pioneer coaxials... by quite a lot. They are designed off axis and will fill the cabin better too.
The kodas move 7mm... pioneer coaxials move maybe 3
[Modified by Kale, 3:38 PM 5/18/2003]
Old May 18, 2003 | 06:52 PM
Kale's Avatar
Kale
almost forgot about these
CL-61a
http://thezeb.com/caraudio/CDT_Audio_Components.html
CDTs are awesome comps, $300 for 2 pair. Less than Koda, plus its 4 speakers like you want.
Maybe a round of those, and a set of JL 6WO (if you can even find them)
To I need a 6 3/4" sub. Do they exist?
