Sponsored by: Innova
fustrated
Old May 22, 2003 | 04:21 PM
pdd000's Avatar
pdd000
Default fustrated
i started off with kicker 6.5's. they distorted with the amp gains way down. i sold those and bought mb quart 6.5's, now those are distorting at low gain levels. so i said f this i bought cdt es-620's, so iam waitin for thoseto come in the mail for the front. my amp for the fronts is a kicker 4channel. is this kicker amp giving me all this BS or am i buyin the wrong speakers. if its the amp tell me a good four channel amp, this is gettin tiring ripping the doors off every week :banghead:
Old May 22, 2003 | 04:33 PM
leolufse's Avatar
leolufse
Default Re: fustrated (pdd000)
Don't know about the kicker components, but there is no reason that the MBs would distort. Since you have to turn the gains way down, my guess it is either the amp, or the installation. Perhaps you have the crossovers set wrong, or have the amp bridged across the wrong channels.
Old May 22, 2003 | 04:38 PM
pdd000's Avatar
pdd000
Default Re: fustrated (leolufse)
i checked the crossovers there ok. also i checked the amp settings. i also checked the wiring. it sounds good till i turn it up on the radio . i have all the crossovers on the radio off. so i just use the ones from the amp. :banghead:
Old May 22, 2003 | 04:43 PM
Metal Wulf's Avatar
Metal Wulf
how much power are you feeding the comps ??
Old May 22, 2003 | 04:56 PM
pdd000's Avatar
pdd000
Default Re: fustrated (Metal Wulf)
the kicker amp is rated at 75x4watts RMS.the comps are mb quart dsd216's
[Modified by pdd000, 3:57 PM 5/22/2003]
Old May 22, 2003 | 05:06 PM
Metal Wulf's Avatar
Metal Wulf
are you just using the fronts or did you bridge it ?
Old May 22, 2003 | 05:43 PM
pdd000's Avatar
pdd000
75 in the fornt and 75 in the backs
Old May 22, 2003 | 05:49 PM
CarbonTuning's Avatar
CarbonTuning
Zapco, Arc Audio and Phoenix Gold would be my choices. Theyd look/sound better than the Kicker :)
The ES's are going to need a little bit more power. Probably in the 150w range.
To fustrated
