Sponsored by: Innova
CD changer operation??????
Old May 24, 2003 | 07:59 PM
Ram Air Tony's Avatar
Ram Air Tony
Default CD changer operation??????
How does the CD head unit run the CD changer??? I thought that if you had no CD in the head unit, and pushed CD/ AUX, it went to the changer :confused: .... mine doesnt :confused:
the harness came with 2 plugs, I only plugged the one into the taped up harness for the changer?!?!
what is goin wrong????????
thanks
Old May 24, 2003 | 09:09 PM
Bob Chapman's Avatar
Bob Chapman
Default Re: CD changer operation?????? (Ram Air Tony)
Tony - go to Audio and Electronics with this question.
Old May 26, 2003 | 03:24 PM
sodian's Avatar
sodian
You need to plug in the other connector thats under the passenger side floor board. With the CD head unit you press the CD button. One push will start up the in dash player, a second push will switch over to the changer. The car manual includes the instuctions for operation. The manual that comes with the CD changer does not cover the CD head unit.
Old May 26, 2003 | 04:19 PM
Ram Air Tony
Default Re: CD changer operation?????? (sodian)
sod.......I went back and plugged both in, but now the dad gum MAGAZINE is stuck in the changer and it appears that it may flip some type of breaker in the changer, cuz it shuts down after I click the door.....and the magazine wont pop out like it should :banghead:
thanks
R
A
T
Old May 28, 2003 | 05:20 AM
vrumvrum's Avatar
vrumvrum
I got my magazine stuck too. Had to remove the changer, remove the cover and as I vaguely remember, I may have been drunk at the time, pressed a lever that was pretty obvious and it popped right out.
Old May 28, 2003 | 08:25 AM
Ram Air Tony
Default Re: CD changer operation?????? (vrumvrum)
thanks for the help.......looks like I am gonna have to take her apart :banghead:
thankss
R
A
T
To CD changer operation??????
