Sponsored by: Innova
What does DVC mean?
Old May 29, 2003 | 12:40 PM
TIMSPEED's Avatar
TIMSPEED
Default What does DVC mean?
I know DVC means Dual Voice Coil's...but I mean..what does that REALLY mean? More bass, or what? :confused:
Old May 29, 2003 | 12:41 PM
Kale's Avatar
Kale
Default Re: What does DVC mean? (TIMSPEED)
it means the subwoofer is more "flexible"
a dual 2 could be wired as 1ohm or 4ohm
a dual 4 could be wired as 2ohm or 8ohm
Old May 29, 2003 | 12:46 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: What does DVC mean? (Kale)
Still :confused:
You mean if I bought two DVC Subs that were 4ohm, I could actually run them at 2ohm's each and squeeze more power out of my amp?
Old May 29, 2003 | 12:55 PM
TIMSPEED's Avatar
TIMSPEED
ok, here's the subs I'm going with:
http://www.sounddomain.com/sku/KIC03CVR84
What would be a good amp to run them with?
(I'm getting the subs today, local place is having a sale, they're $80 for 2.)
Old May 29, 2003 | 01:34 PM
Metal Wulf's Avatar
Metal Wulf
you can wire the pair into a 4ohm or 1ohm load.
Old May 30, 2003 | 07:35 PM
madquake's Avatar
madquake
Still :confused:
Yes and no .... Tim.
Let me try to set some light to the shade here .... 13 years in this field should come in handy.
Yes you should be able to "SQUEEZE" more power out the amp running a 2 Ohm load.... Granted your amp is designed to run at 2 ohms!!!
Most quality amps this day in age can run at 2 ohms ... need to research your amps specs.
Now on the flip side if your amp is not designed to run at 2 ohms and you still do it .... Its just a matter of time you will damage it.
Dual Voice coils exsists on subwoofers for the simple flexibility of being able to run a single sub in a car due to some of space restrictions and also for the flexibility of being able to run them at 4 or 2 ohms some cases 8 to 4.
For DVC's In most cases the amps are to be run in "Mono" mode .. which is when a amps' wiring scheme is changed from the standard "stereo Config"
to a single output config .. using in some cases in combo switches and different speaker leads from the stereo config ..... the amp runs at full output this way to that single speaker!!
The power rating of the amp is usually higher when run in mono and in certain ohms 2 or lower so it drives that one speaker....
So its safe to say most DVC's are run alone as a single Sub!
In some cases a bunch of DVC's are run in competition to get the ohms really
low when "Cheater amps" are being used!!
This suckers run at a 1/4 ohm and make some sick power!!
They rate very low so they squeeze into smaller watt classes but when wired up to these ohm loads can put out some sick power!!!
My zues hifonics runs at 600 watts rms at 4 ohms 300X2. @ 4 ohms Stereo.
But it can also run "mono" at 2 ohms for 900 watts rms Total.
Up to me to show it 2 ohms so I can squeeze that extra 300 watts RMS.
In this case a really high end DVC Would be good !! here so I can show it 2 ohms ... I would be crazy to use anything less than a 15 inch Sub... a 18 inch would be more suitable... its alot of power and anything too small would die.
Hope this helps ....
Mark A.
Old May 30, 2003 | 08:35 PM
Kale's Avatar
Kale
Default Re: What does DVC mean? (Metal Wulf)
There are 10's that can handle 900 watts easily. W7, MAX, Brahma, perhaps the 10A. Only the real quality 10's can, though.
Old May 30, 2003 | 08:41 PM
Metal Wulf's Avatar
Metal Wulf
:withstupid:
I'll be giving a 10A a 1000 watts, and that's not even near hitting it's max...
Old May 30, 2003 | 09:18 PM
madquake's Avatar
madquake
I've blown Competition ... JBL 1000's 15 inch subs with this amp.
The specs on them are 1000 watts RMS from JBL!
Always remember that there's a big difference between Peak Power handling and RMS .... I suppose there may be a few 10's out there where the man. claims 900 watts rms...
But in the real world I've seen bigger and badder subs than a 10 inch roast under such power condition!
Personally I wouldn't give a 10 inch sub a week to live wired to my zues!
Also alot of this is based on the type of music you listen as well!
Mark A.
Old May 30, 2003 | 09:43 PM
Kale's Avatar
Kale
Default Re: What does DVC mean? (madquake)
I'd trust any of those subs I named, when INSTALLED PROPERLY with 20-80hz cycles at full volume, 1100 watts rms or more.
Old May 30, 2003 | 09:50 PM
madquake's Avatar
madquake
yah those are some moma jamma subs.
:yesnod:
Old May 30, 2003 | 10:37 PM
Kale's Avatar
Kale
I'm getting an 8" A sub and giving it 500 watts. :yesnod: The newer speakers are handling more and more power.
Old May 30, 2003 | 10:40 PM
Metal Wulf's Avatar
Metal Wulf
I love those little 8A's :smash:
Old May 30, 2003 | 11:01 PM
sodian's Avatar
sodian
I have a pair of old Infinity's and the dual voice coil means just that. There are two coils on the woofer (4 wiring connections from the crossover) Each coil is optimised for a certain portion of the low frequency range.
[Modified by sodian, 10:02 PM 5/30/2003]
[Modified by sodian, 10:03 PM 5/30/2003]
To What does DVC mean?
