Sponsored by: Innova
cdt speakers
Old Jun 4, 2003 | 02:02 AM
pdd000's Avatar
pdd000
Default cdt speakers
i have the cdt es-620 component speakers. i have a kicker 4channel amp 75watts rms runnin these and the rear speakers.. will 75watts to these speakers hurt them? should i bridge the kicker amp and forget about the rear spaeakers?
Old Jun 4, 2003 | 02:21 AM
Kale's Avatar
Kale
Default Re: cdt speakers (pdd000)
75watts is not nearly enough power to damage ES's. I would try bridging it and seeing how it sounds with just the ES.
Old Jun 4, 2003 | 02:22 AM
Metal Wulf's Avatar
Metal Wulf
i vote bridge it :thumbs: i don't think 75 is enough power for the ES's
Old Jun 4, 2003 | 08:34 AM
mrkln's Avatar
mrkln
Default Re: cdt speakers (Metal Wulf)
:withstupid:
Old Jun 4, 2003 | 11:25 AM
Conquer's Avatar
Conquer
St. Jude Contributor
:iagree: .....add another vote for "bridge"
Old Jun 4, 2003 | 12:09 PM
pdd000's Avatar
pdd000
thanks guys ill brigde it and let u know the outcome :)
Old Jun 4, 2003 | 03:24 PM
DSTJ99's Avatar
DSTJ99
Which amp is it? The KX series really mulitply fast when you bridge them so BE CAREFUL. The KX600.4 is 75x4 or 300x2. 300x2 is too much for Eurosports, but 150-200 would be perfect.
Old Jun 4, 2003 | 03:35 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: cdt speakers (DSTJ99)
eww... i also just looked up the specs. that 300x2 is also a bridged mono.
Old Jun 4, 2003 | 06:02 PM
pdd000's Avatar
pdd000
ya its the kx600. 300x2. should i forget it then? i also so meant in an earlier thread if 75watts rms would hert them because the wattage was too low?
[Modified by pdd000, 5:04 PM 6/4/2003]
Old Jun 4, 2003 | 06:56 PM
Metal Wulf's Avatar
Metal Wulf
to little wattage can't hurt a speaker... they just won't get a loud as they could.
I wouldn't bridge them, 300 is a little to much plus they'd be mono...
Old Jun 4, 2003 | 06:58 PM
pdd000's Avatar
pdd000
thanks for the reply :yesnod: :yesnod: :cheers:
Old Jun 4, 2003 | 07:38 PM
Kale's Avatar
Kale
No... Idont understand why this myth exists... If you think about it... every time you turned your speakers down, theyd blow up.
To cdt speakers
